Results 1 to 9 of 9
Thread: Removing rear shocks made easy
    Canada, ON
    Default Removing rear shocks made easy
    Thanks to a fellow E34 owner (Marc L.), he gave me a great trick to pop the rear shock out of the axle.
    You need a massive round piece of solid bar stock. You place it against the lip of the shock (I will take pics later) on the caliper side of the shock.
    Then with a 5lb hammer, you hammer it a couple of times and scream with joy as the rear shock comes out...
    This was the easiest way of doing it. It usually takes me 20 min to pull it out, this time it took less than 3...
    Mar 2007
    Liverpool UK
    A three-legged gear puller does the business too...
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Feb 2007
    New Forest, ,UK,
    And of course Bruno,everybody has 6` of 2" bar stock in the shed! Gorilla factor will remove anything on an E34...........
    I really don't get it... It seems like for all you guys... the rear strut is rusted into the axle... When I changed mine, I just slip it out with my hand.... no hammer, no swearing, nothing... just 1 second and it pops out. Both side of rear strut is simple 1 second.
    Canada, ON
    Snow + salt = rust... lot's of it...
    Nov 2006
    Mid-Atlantic, USA
    I'm with you, Tiger. Just did my rear shock mounts with no difficulty. Glad I didn't read this first!
    El Paso TX
    ditto, mine came out by hand as well.
  1. Rear brake backing plates - easy to R&R?
    By E34-520iSE in forum 5 Series BMW
    Last Post: 01-03-2010, 11:31 PM
  2. Replies: 0
    Last Post: 07-15-2008, 03:07 AM
  3. Replies: 4
    Last Post: 07-14-2008, 02:42 PM
  4. 730i/replacing rear axle carrier rubber mounting/easy?
    By nsbone_1988_520i in forum 7 Series BMW
    Last Post: 07-01-2007, 05:04 AM
