Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: Guys with broadband connections..here is a free ETK
    Unregistered Guest
    Default Password
    Quote Originally Posted by Chad535
    I must say it is a large download, but it works and is worth it.
    http://crass.on.ru/bmw/etk/
    Do you know what's the password to install? Thanks
    Installation instructions are as follows:
    1) insert the ETK CD into your drive. Go to %driveletter%:\win95\bmw\etk and run setup.exe. This installs the Sysadmin part.
    2) From the Sysadmn tool click EPC, then install. This loads the ETK/EPC stuff. This can take a while to install.
    3) From the Sysadmin tool click TIS, then install. This loads the TIS. I believe you can load this onto your PC or have it so it will require the CD.
    If you install in this order you shouldn't be prompted for a password.
    FYI the newer ETKs don't seem to have as many e34 parts as the older versions. Some part numbers have changed since then, so if you as for a specific part the vendor might use another number. This has happened to me before, esp with bulbs.
    Apr 2004
    Oxford, England
    What program should I use to open the EBA once downloaded?
    If it's an iso, you can burn it to a CD with Nero (or any burning software) or you can use Winrar (rarsoft.com I think) to open and extract it. If you want to install but don't want to burn it you could mount the image with DemonTools or the like.
    netmgr Guest
    Default dont bother with EBA
    The EBA has nothing regards E34 in it, dont waste a 500meg download!
    its just got the E39 i think
    you need an older version im guessing..
    darren
    I have installed the ETK many times and this is the first time it has ever asked for a password. The password is "berlin56." (without the quotes).
    have you seen the 2 samples I linked abv? That was for E34 and E32.
    I have plenty of more samples available for E 32/E34, because it is usually the same.
    Default Shogun this eba is a newer version and it doesn't contain any info for
    e32 and e34... I imagine you must have an older version that does.
    Default If there is any remains of an older version on your computer then it will ask for a
    password.
    Quote Originally Posted by happifella
  10. #20
    netmgr Guest
    Default the TIS
    The TIS is in Russian regardless of the language you pick...
  1. Free broadband from Google
    By Tiger in forum 5 Series BMW
    Last Post: 04-02-2007, 09:05 AM
  2. E34 540 Leaking Brake fluid at MC connections
    By Tirnanog in forum 5 Series BMW
    Last Post: 01-11-2006, 12:43 PM
  3. Replies: 5
    Last Post: 12-30-2005, 05:07 PM
  4. Electric recaro connections
    Last Post: 07-20-2004, 06:32 AM
