Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Leaking coolant on '95 530
    Wellington,New Zealand
    Quote Originally Posted by Jon K View Post
    I dunno I was thinking of replacing the water pump and t-stat alone. The o-rings on the front side of the engine as well I suppose. Whats the point of that pan? I don't see how it does anything. I am not very well versed on BMW V8s. Why would it be wet, and what does it do?
    they are the valve covers arent they?
    Feb 2007
    New Forest, ,UK,
    Quote Originally Posted by yaofeng View Post
    You're going to find two o-rings behind the water pump. Are you going to stop there?
    Pulling the intake is not hard.
    You don't need to touch the valley pan if it is dry. If you do, you can not simply replace the pan gasket. BMW no longer sells it. You need to buy a new pan. It has the gasket baked on.
    Thats good ol` Sikaflex, $4 a tube with nozzle.
    You stand a chance of disturbing the rear o-rings while doing the pump. they can be done w/o removing the intake.
    East Brunswick, New Jersey
    Quote Originally Posted by Barney Paull-Edwards View Post
    It came to my mind. Then I decided I wasn't going to dive in again for another 60k miles, perhaps more. Knowing how many times I screwed up DIY in the past even with kind replacement, the decision was easy.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Reading, UK
    My question was - is there coolant under that cover? I dont understand what it is - I dont do V8s traditionally.
    Yeah the V8 has a bath/galley that runs down the centre top of the block to cool the top edges of the pistons... quite common for the later M62s to spring leaks here past the 100k miles mark.
    PA
    Thanks Ferret - jeez thats a strange thing - leave it to bmw!
    Her had an alusil block put in, so I suspect all the seals and such are newer than the chassis, which has probably 140k or so. So the motor is probably at 40 - 50k miles which is water pump territory. I am replacing that stuff first and if I have to I'll go back in for the valley pan. All in all, this stuff isn't nearly as daunting as what I've done to my car - it should go well.
  1. Coolant and possibly oil leaking at front of engine
    Last Post: 09-07-2010, 01:21 PM
  2. Where's my coolant leaking?
    By ScottyWM in forum 5 Series BMW
    Last Post: 07-10-2006, 11:22 AM
  3. Leaking Coolant
    By 1995 525i in forum 5 Series BMW
    Last Post: 02-26-2006, 07:40 PM
  4. Help! Coolant Leaking
    By slip in forum 5 Series BMW
    Last Post: 09-11-2005, 11:04 PM
  5. leaking auxiliary coolant pump
    Last Post: 06-28-2005, 07:07 PM
