RealOEM have a page with part numbers for various plugs etc. http://www.realoem.com/bmw/partgrp.d...82&hg=61&fg=15
That is for an '89 535i.
I have a couple connectors that I am trying to replace but can't find a part number for them. Any ideas? As you can see they are toast
1. Three pin connector from the AC compressor
2. 2 pin connector
3. same type of 2 pin connector
4. Plug on the heater valve
Ken, from Melbourne AUS.
'89 535iA with a 5 speed swap.
aux fan connector to the switch on radiator
Plug housing
Part number: 61 13 1 378 410
old p/n -Alte Teilnummer: 61 13 0 492 947
got one from Germany
http://www.7-forum.com/forum/5/teiln...ter-91890.html
the old one has different design for the connector in agled design. But the pins with wire in angled design do not fit to the new connector. You need straight pins. So either buy some new pins with short wire attached and resolder them, or find old cable looms and cut these off and resolder them.
Then I investigated further in the 2 and 3 pins, for example shown on the engine oil level plug. The female plug you can get from BMW, but not the other one. I also got these from Germany from Bosch, I now have 3 pins and 2 pins connectors, both sides, and the male and female pin, plus the rubber protectors for them.
Here are the numbers
Kupplungsstecker 3polig. =Boschnr.1 928 402 448
hatte damals 0,98 Euro/Stk gekostet.(ohne Mwst)
Und weil ich schon dabei bin.
Kupplungsstecker 2polig = Boschnr.1 928 402 452
Und die Gegenstücke:
2-polig = 50290236(Herth+Buss)
3-Polig = 50290238(Herth+Buss)
Und hier die Nummern für die Tüllen(Gummiteile am Kabeleingang):
2-polig gerade 50281050(Herth+Buss)
2-polig abgewinkelt 50281051(Herth+Buss)
3-polig gerade 50821052(Herth+Buss)
Und noch die Steckkontakte
Flachstecker: (für die Kupplungstecker): 50253315(Herth+Buss)
Flachsteckhülsen: (für die Gegenstücke) 50251813(Herth+Buss)
also see
Plug housing 2-POL 2,88 € 12 52 1 706 121
Plug housing 3 POL. 3,50 € 12 52 1 706 068
(ist AMP Nr. 827578)
http://bmwfans.info/original/E32/Lim...2/ill-12_0327/
more here
http://www.7-forum.com/forum/5/steck...mer-94625.html
single pin connectors, also no shown in ETK, but available from BMW:
Buchsengehäuse einpolig: 61 13 1 378 460
Steckergehäuse einpolig: 61 13 1 378 465
about $1 per piece
http://www.cbdj.de/forum/stecker_einpolig.jpg
not only there, that is for the chassis, here the ones for engine room
http://www.realoem.com/bmw/partgrp.d...82&hg=12&fg=31
BMW uses AMP TYCO, also check here
http://www.action-electronics.com/ampcpc.htm
http://www.alliedelec.com/
http://parts.digikey.com/1/parts/104...5179031-5.html
http://www.tycoelectronics.com/
http://www.keefeperformance.com/
Wiring Harness Terminals
http://www.ratwell.com/technical/Terminals.html
Problem with RealOEM is they show male fittings but not the female. Trying to figure out which components go together is a real pain. I am thinking about using Weatherpak. They come in 1 to 6 wire configurations all I have to do is figure out wire gauge sizes. Oh I am sure there will be someone who will make a sexual reference to this response. Always is................
Need to replace the plug on the coolant sensor but can't find it either
i have a lot of those i need to replace i was just going to order a bunch of either #7 or #8 (7 i'm pretty sure for foglights, temp sensor size plugs) and connect the wires individually you can order them at pelican parts. i'll probably use rubber electrical tape where the plug goes in this case, maybe you'd prefer to do a better job yourself...
http://www.realoem.com/bmw/showparts...61&fg=15&hl=17
for now i'm making do with canadian tire parts... they suck they are hard to size around the male connector.
Just found a Bosch online catalogue with plugs/connectors and even drawings, there you can select what you need
http://www.bosch-connectors.com/bogscoca/home?locale=en
