Results 1 to 8 of 8
Thread: Steering Help!!!
    Markham, Ontario
    Default Steering Help!!!
    Hello everyone, I have a question and need some advice before I bring my 1989 525 to the mechanic.
    Here it is.... my car has been sitting for sometime I have been so busy with work that I have not driven it all summer and when I drive it in and out of the garage the steering is verry stiff and hesitaes to move left and right it will turn with some added work.....
    Do I need a steering box or do I need a steering rack?
    any advice would be helpful
    Thanks Maurice
    1989 BMW 525 - M20--119,000.00-Original KM - now 5-speed
    your car uses a steering box, not a rack.
    Check the fluid first.
    Mar 2007
    Liverpool UK
    Quote Originally Posted by specialguess View Post
    Thanks Maurice
    How's the power steering pump doing? Mine groans like hell when I'm parking, I think I need to replace it soon as the funds allow!
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Apr 2008
    Washington DC
    Quote Originally Posted by e34.535i.sport View Post
    Hmm, I heard that the 535i power steering pump was indestructible...maybe it can be repaired without replacement.
    1989 11/88, M30B35 175k-miles 535iM
    1988 04/87, M20B27 153k-miles 528e
    1987 01/87, M30B34 126k-miles L6
    Washington D.C
    Mar 2007
    Liverpool UK
    Quote Originally Posted by Sixdown View Post
    My DIY (destroy it yourself) skills are unprecedented... Maybe a fluid change will do the trick?
    Minneapolis, MN
    Thanks Maurice
    It definitely sounds like you have no power steering. The pump is probably bad. Could have leaked all the fluid out while it sat. You do have both serp belts still, right? It's highly unlikely that the steering box went bad while sitting still...though I'm not sure what would happen if the seal broke on a steering box.
    BennyM
    Markham, Ontario
    Thanks for all your advice guys I am going to have to check in to it further
    I have repaired my power steering pump with a set from USA, works well again, no noise, no leaks, and all that for 20$, the set consists of the seal, the O-rings and 2 profile rings, no metal parts.
    Sold by the seller "for offroad use only".
    Fits many ZF pumps.
    http://www.bimmerboard.com/forums/posts/535277/
    I also repaired my steering box with a parts set from BMW, they still had some sets, no more available in the future. Cost me about $50 from Germany from my dealer there.
  1. Steering
    By Exnilo in forum Suspension & Steering
    Last Post: 08-31-2005, 05:43 PM
  2. What's up with my steering?
    By mancini_mark in forum 5 Series BMW
    Last Post: 05-14-2004, 08:58 AM
  3. What's up with my steering?
    By Dan in NZ in forum Suspension & Steering
    Last Post: 03-15-2004, 08:26 AM
  4. What's up with my steering?
    By Dan in NZ in forum 5 Series BMW
