Results 1 to 3 of 3
Thread: Door hinges and coolant leaks...
    Default Door hinges and coolant leaks...
    I noticed a strange problem on my car...on the front driver side door, where the hinge is bolted to the inside of the door, the metal is torn and flexes when the door is opened very far...what the heck can I do about this? Also, there is a strange coolant leak that I can't see somewhere around underneath the pedals or so...any ideas?
    El Paso TX
    koala door brake kit.
    coolant? or hydraulic fluid from your clutch pedal?
    Sep 2007
    Seattle, WA
    Here's that Koala door brake kit.
    http://www.koalamotorsport.com/prodd...=DRPE32&cat=74
    Works great, have 'em on my car and have installed them on an M5 as well.
  1. Coolant leaks galore w/ excessive pressure…
    By RockJock in forum 5 Series BMW
    Last Post: 02-22-2010, 09:57 AM
  2. M30 engine oil leaks
    By Rus in forum 5 Series BMW
    Last Post: 02-27-2009, 12:12 PM
  3. check your fuel/gas flap brackets/hinges
    Last Post: 12-26-2008, 11:42 PM
  4. M20 Engine Oil Leaks
    By JShep in forum 5 Series BMW
    Last Post: 04-30-2008, 01:07 PM
  5. changing gas filler door hinges+ spring clip-DIY
    Last Post: 04-17-2008, 05:44 PM
