Results 1 to 3 of 3
Thread: acceleration and hesitation on my 535i
    Jan 2007
    Dayton Ohio
    Default acceleration and hesitation on my 535i
    Performed the stomp test, got the no fault code. The e34 hesitates or misses on acceleration. Where should I start? Cleaned the intake and installed new air filter. Anyway of checking the ignition wires?
    Use a multimeter and test
    distributor cap
    distributor rotor
    all ignition cables and their plugs
    easy to do. Details are in the Bentley manual. If you do not have a Bentley, just test them all and the one which is different is faulty.
    I recently had a friends E32 750 for checking here, engine was runniung really rough. Found the distributor had haircracks, 8 out of 12 ignition wires did not have the right Ohm.
    Dec 2005
    while you are at it, clean icv, throttle body with carb and choke cleaner.. check plugs too..
  1. Hesitation at take off
    By vping in forum 5 Series BMW
    Last Post: 12-25-2008, 12:58 PM
  2. Hesitation - Possible Causes
    Last Post: 08-29-2008, 05:04 PM
  3. What causes a 1 second hesitation?
    By wjbell in forum 5 Series BMW
    Last Post: 07-02-2007, 03:57 PM
  4. M30 Afm Fix No More Hesitation
    By clhorton in forum 5 Series BMW
    Last Post: 10-01-2006, 11:44 PM
  5. Replies: 4
    Last Post: 10-30-2005, 07:33 AM
