Hey,
Apparently I've had another thermostat failure. It's still being replaced, so I'll know for sure if it's the culprit later - you just never quite know. Symptoms as reported by the mechanic is that the top hose was hot, while the bottom one was cool (could be other way around as far as my memory serves me) which would indicate the thermostat did not want to "open up".
Thermostat was replaced Feb. of last year. I wonder that the coolant has anything to do with it failing. I top it off with Prestone LowTox aluminum compatible, which is probably not what my usual mechanic uses. In fact, I have not done my homework on the subject properly now that I think about it.
Thanks for your input.
