Results 1 to 5 of 5
Thread: Part Throttle Misfire
    Feb 2008
    Wausau, WI
    Default Part Throttle Misfire
    Developed a partial throttle mis-fire last night. Idles smooth, cruises smooth, mis-fires and stutters on acceleration. Like it's on 5 sylinders. No CEL. Going to put new plugs in and inspect coil packs and wires tonight. Thought I would see who else has any other ideas. Thanks!!
    Pat Washburn
    Wausau, WI
    1995 525iT
    Nov 2005
    O2 sensor maybe.
    Default most likely one of your spark plug
    tubes has leaked oil and is shorting out the coil , or you have a plug that the gap is too wide or a damaged coil to plug insulator.
    Quote Originally Posted by Washburn View Post
    Feb 2008
    Wausau, WI
    Bingo! You're right on with the oil. I replaced plugs last night and a couple of the plugs were bathed in oil. Cleaned it all up and everything is sweet!
    Now next question, is that a simple valve cover gasket type fix? I didn't see any obvious signs of a leak point....how does the oil get in there? I'd like to button it up tight. Thanks!!
    Pat Washburn
    Wausau, WI
    1995 525iT
    Yes, it is valve cover job.
  1. Two part question- throttle cable-coolant hose
    By russiankid in forum 5 Series BMW
    Last Post: 08-21-2008, 10:30 PM
  2. could i get a misfire?
    By dwaynos in forum 5 Series BMW
    Last Post: 06-07-2008, 11:47 AM
  3. part number question- clip for throttle cable
    By bbig119 in forum 5 Series BMW
    Last Post: 03-04-2007, 08:57 PM
  4. Part Throttle wot surging, ABS Light...
    By aston_jag_tech in forum 3 Series BMW
    Last Post: 02-07-2007, 08:35 AM
  5. m30 535i Part Throttle Flat Spot
    Last Post: 07-01-2005, 01:39 PM
