The input shaft bearing on the trans would suffer worst I'd think, someone here might have the spec for allowable play.
So i just go my transmission for the third time now and it was just as fun as always, however i didn't find what i expected. After getting the pressure plate and clutch disk off i noticed the nipple on the end of the transmission input shaft had surface rust on it. Thus it couldn't have been properly seated in the input bearing. I grabbed and alignment tool supplied with the clutch kit and shoved it in the bearing but it was loose and the bearing looks brand new.
I noticed the clutch kit comes with two guide tools and bearings, same spline but different diameter nipples. I must not have realized to swap the bearing when i swapped transmissions awhile ago.
Can anyone think of any issued that could be related to the input shaft of the transmission effectively not having and input bearing to support it, noises, damage, etc? I am finding a pilot bearing puller tomorrow to swap it but i am curious if this could be one of the elusive clunking noises that drive me.
Sorry that wasn't a very clear post, the rust was just what got me to actually look and measure the bearing. The bearing that is in my crank is the larger one pictured below, the smaller bearing that fits is the new one that came with the clutch kit.
I haven't been able to get the old one out yet, i just tried the pilot bearing puller tool from harbor freight and it would not fit a bearing this small. Has anyone had any luck with the autozone tool?
Are there any particular procedures to testing a dual mass flywheel, are they prone to failure and if so what are the symptoms? I can rotate mine roughly 15degrees before the crank starts to turn but its not loose or anything.
The surface has some heat marks but is still smooth for the most part. Will a clutch "bed" into this like brake pads on old rotors?
