Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: What is this panel called
    Jan 2007
    Dayton Ohio
    Default What is this panel called
    Heres is another one. I think this is part of the headlight setup but the illustration on RealOEM doesn't look anything like this. (Part number #11)
    Part number 51711946434
    Any ideas?
    Dunlap Illinois
    It's called the right inside covering. The picture on Realoem depicts the left side.
    Jul 2004
    New Haven, CT
    I'm pretty sure the air cleaner snorkle fits in the round cut-out, not sure if you can mount it right with the beat up tabs however...my US model 2.5 l has the same part.
    Good luck,
    John
    It depends on engine type, not all E34 have it installed.
    Dunlap Illinois
    Here's the correct part number you need for the right side covering. 51711946434 Realoem says it's good from '89-'93, unless you have the headlight cleaning system.
    The circle cutout accepts the intake horn for the air cleaner, the cutout has a plastic plug for the M5 since the air intake is on the other side. There are a couple of plastic screws and anchors for attaching it as well, see item #12 on your diagram.
    Jan 2007
    Dayton Ohio
    Pelican parts show a pic of it but no price. Also tried Bavauto and Autohaus but they don't carry it. Anyone know where I can get this panel. For now I will weld the old one and put it back on. I have a plastic welder, works pretty good as long as I weld a piece of stainless screen into the tab.
    El Paso TX
    dealer? BMA?
    junkyard / parted out car?
    Jan 2007
    Dayton Ohio
    BMA ...Not on their site but I asked if they could locate one
    Wellington,New Zealand
    the alternator cooling duct also goes into the "inner cover" on my 535
    Gone but not forgotten
    Jan 2007
    Dayton Ohio
    Interesting....the intake manifold goes into mine.
  1. What are these called?
    By Calico_NC in forum 5 Series BMW
    Last Post: 06-14-2006, 01:57 PM
  2. NEED HELP ASAP ~what is this called?
    By wheelerdealer in forum 5 Series BMW
    Last Post: 05-06-2006, 06:28 PM
  3. Why has no one called BMW out?
    By zhandax in forum 5 Series BMW
    Last Post: 01-12-2006, 12:15 PM
  4. I just called for a price on the X3 3.0.....
    Last Post: 10-01-2004, 06:03 PM
  5. whats yours called??
    By Ian w in forum 5 Series BMW
    Last Post: 07-06-2004, 01:17 PM
