Results 1 to 9 of 9
Thread: SRS Light
    Sep 2007
    Ottawa, Canada
    Default SRS Light
    Had SRS codes read today by Indy - 1995 525i
    Codes displayed
    2 - Firing circuit Drivers airbag
    5 - Firing circuit Passenger airbag
    19 - Warning lamp faulty
    SRS reset and codes 2 and 5 did not display after reset
    Code 19 still showing after reset and SRS Light always on.
    Any Ideas - Thanks for any help offered
    Default The airbag warning light on the dash has
    actually got 2 lights in it. One is the bulb which is a conventional bulb , the other is a led which is in parallel with the bulb, if the bulb fails the led will continue to light up but you'll get the bulb fault code. Pull the dash cluster and change the bulb.
    Quote Originally Posted by 525i View Post
    Codes displayed
    Sep 2007
    Ottawa, Canada
    Default SRS still on
    Thanks for the suggestion.
    I replaced the bulb and had the SRS Reset and Error 19 -Warning lamp faulty did not go off.
    Any other thoughts - Thanks for your efforts
    May 2006
    NH
    Maybe remind him to disconnect the negative battery cable before unplugging the Cluster wires..I forgot to do that the other night when I tried again to get a bulb in without fully removing the cluster and now the SRS light stays on for a few minutes after ignition but goes out. Will a reset stop that?
    1995 540i Manual build 1/95
    Jan 2007
    Dayton Ohio
    Did you replace the bulb on the circuit board? Not just the one that screws into the panel.
    Sep 2007
    Ottawa, Canada
    Default Circuit Board Light- SRS
    Quote Originally Posted by Kibokojoe View Post
    I only replaced the bulb on the panel. I think the light on the circuit board is working, when the panel bulb was removed the SRS was still dimly lit.
    Is it possible the 2nd lamp would be working and the fault code still registering.
    Thanks for the advice - this is driving me
    Jan 2007
    Dayton Ohio
    I don't have a clue. Logically if the circuit board light is working then it has to be the panel light. How do you know that the panel light is working? Easy enough to check the bulb but the panel circuit is another matter.
    Sep 2007
    Ottawa, Canada
    Default SRS - Negative battery terminal
    Quote Originally Posted by Jehu View Post
    When I pulled the instrument panel to replace the bulb I had the battery disconnected. When I replaced the bulb I was able to replace it without removing any of the connectors so I did not disconnect the battery.
    Thanks for helping out - I will keep trying.
    Jan 2007
    Dayton Ohio
    I think he is talking about resetting the computer by disconnecting the battery for a couple of minutes.
  1. mounting the light insert with the light housing
    By grave77 in forum 8 Series BMW
    Last Post: 10-24-2008, 01:57 PM
  2. abs warning light, pad wear light
    By Lordsneldon in forum 5 Series BMW
    Last Post: 05-26-2008, 06:33 PM
  3. Brake Light, Tail Light, Licence Plate warnings
    Last Post: 09-24-2007, 05:01 PM
  4. Parking light bulb = signal light bulb?
    By bigtisas in forum 5 Series BMW
    Last Post: 11-06-2006, 11:52 PM
  5. Parking light/reverse light issues
    By cleansdabaffroom in forum 5 Series BMW
    Last Post: 01-06-2005, 10:10 AM
