Results 1 to 8 of 8
Thread: Interesting job today, only about the third time I have ever seen this, it was a
    Default Interesting job today, only about the third time I have ever seen this, it was a
    89 volvo 740 with the aw70 trans and the transmission cooler thats inside the radiator had corroded through in one place inside the radiator...Pulled the pan off the transmission and there was a 1/4 inch of rusty sludge on the bottom of the pan and the screen was completely plugged up with rusty crap too...
    I had just done the fluid and screen a month ago so I knew something was up...the only thing I could come up with was trans cooler leaking so I pulled the radiator and opened it up and sure enough where the fittings join the cooler it was all corroded and leaking internally.. Hopefully this trans will recover from this abuse.. So i'll get to flush the engine and the trans for a couple of hours tomorrow...picked up a new radiator from radiator.com for 150
    Was there any further tell in terms of how the trans shifted or change to either engine coolant or trans fluid color or level? Pretty darn good if that trans can take that level of fluid tainted by coolant and filter blockage and not suffer long term.
    George
    baton rouge, loserana
    it takes a lot to kill a aw70/71/72, overly expensive od solonoid and output shaft bushing wear (fixable) are the only problems i've seen, once on a blue moon one will leak from the pump o-ring by the bellhousing
    Default That transmissions would start to slip to the point that she couldn't drive it and
    if she shut it off and let it cool down she could drive it until all the crap got sucked up against the screen again... there's all kinds of black gook inside the old radiator and the engine but a little oil goes a long way in the cooling system... and the trans fluid level wasn't up noticably but the fluid which was only a couple of weeks old has a really strange coloring but it doesn't look frothy like the engine oil does when you get water in it.. and if you let engine oil sit with water in it it eventually separates and you can see layers, this sat most of the day in some clear bottlles i had just for that reason and it never formed layers...
    Quote Originally Posted by George M
    George
    Default Gotta agree with you Winfred, the aw70 is a japanese copy of the old
    borg warner 3 speed with the 4 gear overdrive added to it... very strong design , but in this case she might have finally killed it...I'll find out today..
    if you can't find one locally i have a few on the yard
    Default Thanks Winfred, here's a few pics of the icky poo radiator cooler and radiator...
    QUOTE=winfred]if you can't find one locally i have a few on the yard[/QUOTE]
    oh nice
  1. So I waxed my car today (56k = Sleepy Time)
    Last Post: 04-07-2005, 12:18 PM
  2. Replies: 5
    Last Post: 02-15-2005, 01:54 PM
  3. Replies: 57
    Last Post: 07-19-2004, 11:39 AM
  4. Interesting find on oil cap today...advise.
    Last Post: 03-22-2004, 01:06 AM
  5. Saw some interesting Bimmers today
    By Paul in NZ in forum 5 Series BMW
    Last Post: 03-21-2004, 01:13 AM
