hoe to take out the blower motor: go to my website below, there is a link to Gale, he has it
I'm having a bit of a problem here. 1st off. I have a 93 525i with 103k miles on it. My blower motor worked only in 3 and 4. Now it only works in the setting 4. What I want to know is that is the controls the same as here http://www.bimmernut.com/forum/showt...ghlight=blower or is the wiring diffrent? And also, wheres the link on how to take out the blower so I can clean it up and lube it? I searched and searched and still can't find it. Thanks in advance.
Thank you!
Doubtful it's your blower motor if it works on 4!
Pull out the resitor/sword and have a look at it
Got similar problem... all 1-2-3 are weak and 4 is sort of medium speed... My car is 1994 540i... so what should I change? I don't think I have the old sword thing.
Did that already... Microfilter is new.
I'll check that out tomorrow after I do m brakes. Thanks for the tips.
this page is super helpful. http://gator482.hostgator.com/~bruno...ower+and+Sword
tiger check it out - you probably have a cheap resistor you can replace.
