Anyone ever have their ATF cooler go out?
I found a pink milkshake when I drained my radiator
Yeah, I had my ATF cooler worn last month on my 540, I saw the pink milkshake you talking about. This is a symptom of a worn ATF cooler, Usually ATF coolers leak fluid in the coolant but coolant does not leak into the oil lines.
leak coolant into the transmission, trashing it out. When you shut off the car hot there is still pressure in the radiator but no pressure in the transmission cooler oil lines so the pressurized coolant makes its way into the cracked or broken oil cooler. I'd pull the trans pan and take a look.
when i dissected the radiator on my m50 car (almost the same rad as your m20) i discovered that the trans cooler on that car is basically a pretty solid metal (paper towel roll sized) tube with two points soldered on for the cooler lines. so while i understand that they do leak, i'm not sure why. perhaps at the solder/weld points for the lines?
Yea, No pink milkshake in the trans pan....
The ol' 525 is back on the road
