Results 1 to 10 of 18
Thread: 98 540i vs 91 525i + $6500
    San Diego, Ca.
    Default 98 540i vs 91 525i + $6500
    I have a chance to get a good deal on a clean 98 540i 6sp. 58,000 miles.
    I have a clean, good running 91 525i that I do all the maintenance on, 160,000 miles.
    From what I spend on the 540 and what I think I can get for my 525 the difference is about $6000 to $7000.
    Like I said I do all the maintence/tune ups and gas mileage is a consideration.
    What do you guys think?
    I appreciate your opinions.
    Nov 2005
    You're likely to get better mileage from the 540, especially since the engine is newer. The key is inertia, where a bigger engine works less to keep a car at speed or to accelerate. People with 540 e34s seem to do better mileage than my non-Vanos M50 525i, by a few mpg. Engine management also has progressed a lot through the years.
    I can't talk about maintenance much; a not too well taken care of recent car will cost more medium term than a well maintained older car, but you know that. Of course you'll have a learning curve for maintenance.
    Even though the car is clean, an inspection will make sure there are no problems about. You just never know what's about to fail. I understand there is another forum where e39s are discussed more. You might want to look into a "what problems arise on the e39" thread, or a "what to look out for".
    If the owner has a record of repairs, that's an excellent thing.
    540i 6sp; sounds very tempting! Good luck !
    baton rouge, loserana
    major roll of the dice on how the 540 will treat your wallet, i had a customer find a good deal on a 98 or 99 i can't remember and in a couple months had spent over $7k on it with us before he said **** this and sold it, it still had a few scheduled failures to go that would of added another grand or two to that
    that's about as bad as it gets but nothing failed that was out of the ordinary just the fact it all hit at once
    Wellington,New Zealand
    you can still do a lot of work on E39,s I am considering the same swap at the moment.Much harder choice though,the car I am looking at is not pristine,however it is only the second one i have seen in 2 years.The best forum for the e39 seems to be this one and there are lots of resources on the web.Like the e34 a lot of the problem that face the E39 owner are the same across the whole model range,whilst the V8 seems to be harder on its cooling system
    Gone but not forgotten
    FWIW I prefer the E34 to the E39 if equipped with comparable drivelines. Not a fair comparison in your circumstance.
    E39s are prone to far more electronics failures as well as your typical E34 foibles. Buy your ABS computer now.
    Visibility stinks, so do the mirrors, the ride and feel are more sedate than the E34. If BMW built Buicks the E39 528 would be it.
    A V-8 with a gearbox makes up for a lot of the negatives though.
    Sep 2007
    Seattle, WA
    As was said above you're likely to get better gas mileage with the 540. I see better mileage on my M-Sport than a friend does on her '95 525iT. And the M-Sport is a much better drive than a 525...
    Benneton (United Colors of)
    your real world highway gas mileage is going to be better in the car that you already have, the better city gas mileage sounds like it makes sense.
    Sep 2007
    Seattle, WA
    Quote Originally Posted by ryan roopnarine View Post
    As far as mileage between my M-Sport & my friend's 525 I see a 1 1/2-2MPG increase over her in city driving, and a 3-4MPG increase in highway driving.
    My car has Dinan engine software and is otherwise stock.
    Her car has stock software, but has UUC underdrive pulleys and a Stewart water pump.
    Forgot to add that I've got my AC on all of the time, she rarely has hers on.
    displacement is what's going to limit the highway mpg. my 1992 525i with 4.10 end and autotrans, eat chip has gotten, at highest, about 36.5 mpg at 55mph. i know that there was a 530i owner on here that was able to snag 35mpg at 55. those are american mpgs, not imperial. i would assume that that depends on what kind of road you are driving on, the age of the oil in your crankcase, et cetera, but even then, the extra litre and a half drops down the maximum, even if the car is loafing along at 2k or so.
    the same car will get 29-30 at 70 mph on fresh 5w30 (ac on) over a relatively short 100 mile trip.
    Quote Originally Posted by bubba966 View Post
    an e39 540i6 has a very high final drive ratio and six gears.At 60 mph its prolly doing less than 2000 rpm.With six gears you can really baby them along,if you want to of course
  1. Sold the 525i, looking at a 540i
    By hk20000 in forum 5 Series BMW
    Last Post: 01-26-2007, 06:36 PM
  2. Can I use 93 525i spring for my 94 540i?
    By Cool Handz in forum 5 Series BMW
    Last Post: 06-17-2006, 12:03 PM
  3. 540i to 525i
    By NorCal5er in forum 5 Series BMW
    Last Post: 08-28-2005, 10:31 PM
  4. 1997 528i 198k $6500$ ????
    By kyleN20 in forum 5 Series BMW
    Last Post: 11-10-2004, 11:34 PM
  5. Do 540i and 525i Diffs Interchange?
    By Cacatfish in forum 5 Series BMW
    Last Post: 03-21-2004, 10:31 AM
