Results 1 to 9 of 9
Thread: Shimmy fix?
    Jun 2008
    Florida
    Default Shimmy fix?
    I have read about the shimmy in the archives, where are the instructions to fix it? I can't seem to find them on here.
    About my problem...
    I feel a very bad shake between 40-60. There is a small shake that stays on from 20-40 and from 60-100 that you can feel too. Does you think that is with the shimmy? I know my rear hydro suspension went bad but I don't know if those have an affect for the front shake.
    SHIMMY @ 80mph – likely culprits
    Check the following in this order:
    1) Wheel alignment by a recommended mechanic (dynamic balancing)
    2) Check your brake pads!
    3) Check thrust arm bushings. (Some call them upper control arms). Bushing can go after several thousand km’s
    4) Replace/check tie-rod center, and Left & Right tie-rods
    5) Check Struts / Shock absorbers while your there.
    6) Sometimes (rarely) disks are warped – replace them (machining is just as expensive if not more).
    Thrust arm
    Apr 2008
    Washington DC
    Thrust arm in my case. I had the shimmy between 50 and 55 so I'm replacing both arms with Lemforder parts.
    1989 11/88, M30B35 175k-miles 535iM
    1988 04/87, M20B27 153k-miles 528e
    1987 01/87, M30B34 126k-miles L6
    Washington D.C
    Jun 2008
    Florida
    If thurst arm is the case, where is the best place to purchase them and are there any instructions on the e34 site on how to replace them?
    get M-50 bushes pressed into the new arms...
    http://www.bmwe34.net/Wiki/tiki-inde...ge=Thrust+arms
    Quote Originally Posted by elbasha View Post
    http://bmwe32.masscom.net/sean750/uc...%20bushing.htm
    That includes changing to the Meyle HD bushes. I also have the complete Meyle HD bush thrust arms installed since 1 year, solved the whole shimmy problem.
    http://www.autohausaz.com/search/pro...int%20Assembly
    http://www.ecartoys.com/RenderScript...entid=ecartoys
    ohh, and at EcarToys you get 5% additional discount if you mention the Bimmerboard discount code
    http://www.bimmerboard.com/forums/posts/539280/
    Wellington,New Zealand
    a very good alignment and balance and if reqiuired new tyres can also fix it.Bad tyres can cause the whole problem,but control arm bushing faiure is the main culprit
  1. no more shimmy!
    By brick8 in forum 5 Series BMW
    Last Post: 02-20-2007, 12:19 AM
  2. shimmy shimmy shake
    Last Post: 06-30-2006, 09:32 AM
  3. NEW shimmy!
    By digitaldragon03 in forum 5 Series BMW
    Last Post: 01-04-2006, 03:08 AM
  4. Shimmy? No thanks!
    Last Post: 10-13-2004, 09:09 PM
  5. Bad Shimmy
    By brandyn in forum 5 Series BMW
    Last Post: 04-17-2004, 04:30 PM
