Originally Posted by
Bo525i
Let me reverse the facts, Iīm riding calmly @ 70 mph on the freeway.. Comsumption is 8,8/100, I now decide to recalculate, keeping speed.. I press the calc and 3 mins later I let go of the acc entirely.. warm engine, no speedups, no real fuel consumption compared to 70 mph,.. the meter passes 30l/100, the OBC registers that fact and I come to a halt, still havenīt touched the acc and I switch off!
Now my consumption shows around 28l/100 so I actually use more gas in idle and with the engine off than @ 70 mph
No, you're not using more gas at idle than you are at 70 mph. You will run out of gas quicker doing 70 than you will sitting and idling.
But, after going through a tank of gas doing 70 how many km did you cover? At 8.8/100km you should've gone 860km. And it would've run you dry a little over 7 hours.
If you go through a tank of gas just sitting there idling and going nowhere how far did you go? 0km. No clue how long that'd take, but it'd be a good bit longer than 7 hours.
Now do you see what your gas consumption gauge is telling you? It's telling you how much gas it takes to cover a certain distance, not how much gas you're using per hour.
Oh, and the OBC average isn't real time unfortunately. It lags a few minutes behind what you're actually doing. So if you drastically change the fuel consumption it'll take a few minutes for that to effect the OBC average.
And that lag can make it really odd sometimes. Occasionally I have fun with the range display and see how much higher I can get the range to read after I've traveled a certain distance. Like when it says I've got 403 miles before the tank's dry. Then I drive 25 miles and it says that I've got 465 miles left before the tank's dry. I increased my MPG so much by driving differently that it raises the average MPG a good bit. And as it's got that lag in the OBC when it calculates the average I've seen it many times continue to go up even as I've sat idling for a minute or two. As in I got stopped at a long light and I've got 464 miles left. Then after idling for a minute or so I've got 466 miles left. I didn't just gain two miles of range by sitting there idling. But due to the lag in the OBC it seems like I had.
