Results 1 to 8 of 8
Thread: Device to test a dash 3W lamp?
    Reading, UK
    Just stick the terminals on a 9v square battery it'll glow dimly - or as shogun suggests, a multimeter will suffice!
    Oldham, England
    Assume you have the dash out or you wouldnt know if it looks good or not. The back of the dash is marked with the wattage by each bulb. Swap it with one of the bulbs that DOES light and you will have your answer.
    Apr 2008
    Belgium
    you are sick.
    I have a multimeter. So I guess you would use it in link mode or whatever it is called. i.e. it bips if current flows from red to black (black to red?)
    I will buy a 12V battery for testing purpose anyway. sounds like fun.
    thx for the input
    Wellington,New Zealand
    Quote Originally Posted by Mordan View Post
    you are sick.
    thx for the input
    you got it,you are checking for continuity,so resistance range .Place rterminals together and you get the bleep.Put terminals across the bulb and you will get a bleep if its good and silence if its bad.Check one of the good ones first to make sure you are doing it right
    Oldham, England
    you are sick.
    Amazing! I really havent felt well for a couple of days
    Great Britain
    The multimeter will probably only beep if it thinks it's seeing no electrical resistance. The resistance of even a cold bulb (the resistance of the filament increases when the bulb is on) might be too high to get any beeps so you might get a false reading of the bulb.
  1. Anyone heard of this fuel saving device - turbomag?
    Last Post: 09-14-2007, 12:35 AM
  2. BMP Fault Code device
    By dcbimmer in forum 5 Series BMW
    Last Post: 08-22-2007, 04:08 PM
  3. Gas saving device - Guaranteed to work!!
    Last Post: 08-30-2005, 03:27 AM
  4. Replies: 2
    Last Post: 02-01-2005, 01:18 PM
  5. 'Check engine' lamp on dash
    By karl1171 in forum 5 Series BMW
    Last Post: 08-03-2004, 01:37 AM
