Finally, after a lot of fiddling around with the clutch slave, doing a total fluid change on it, my 540's finally back and working much better than before.
I've changed all the hardware on the manifold-cat joints, nearly $30 worth of nuts and bolts! Readjusted the rotation of the cat-back exhaust joints and she's sounding so much smoother than before as well.
I have now got two small problems however, the tinkling noise is still there and I've got play in the driveline somewhere (clunking on drive takeup.) I suspect that the two are related and the tinkling noise is coming from one of the CV joints up back.
The propshaft itself is solid, and the bearing/carrier is in good condition. The play is either in the diff or the cv joints and I bet I know which one it is. I suspect one of the CV joints has gone dry and is responsible for the tinkling noise.
Also, I've managed to lose 2mpg somewhere... do you have it? 14mpg isnt amusing at the moment, but I suspect it's something to do with me being out tanning it and doing commuting after the OBC was reset.
Just need to sort out door rust and a dent now and she's sorted![]()
