Originally Posted by
attack eagle
1: there are TWO bulbs in the screen and one behind the keys.
Part number in the bmw database is wrong... the correct bulb is 12v not 6v. Correct number is listed under the CLOCK not the obc.
Remove radio, pull lever (hook tool works great) to disengage OBC, remove and use needlenose pliers to remove bulbs.
Lights in dash cluster: unlikely to be short since it is a circuit board. More likely a bulb with a broken filament or just a loose fitting. Need to take the cluster out to change it.
