Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: #@~$%*^ £&#@! Clutch slipping.
    Feb 2007
    New Forest, ,UK,
    First off try bleeding the slave cylinder properly.If you can get under the car drill a hole so that it faces the plate somewhere near the edge.Place a small pipe(bit bigger than a WD40 pipe) push it just through the hole and give the clutch a good squirt of de-greaser and try car.If it still slipping and if all else fails a good dose of Coca-Cola will clean off crap better than anything else.
    Reading, UK
    Quote Originally Posted by bsell View Post
    Did you get the flywheel ground to remove hot spots during the last clutch job? If you do it this time around, make sure the machine shop gets it right. I don't have the specs for the flywheel but somebody around here probably does...
    Unfortunately the clutch job was done for the previous owner - I have no idea as to the state of the flywheel until it gets removed off the car.
    Wellington,New Zealand
    this happened to a freind with a e 39 540 too.the flywheel either hadnt been machined or hadnt been machined properly or the dual mass cant be machined....
    Gone but not forgotten
    Apr 2004
    In rare cases, the slave cylinder push rod is not fully seated into the cup of the release lever ( or the cup of the slave itself, depending on the design): were that the case, there would always be excessive pressure applied to the pressure plate ...... taking only a small movement of the pedal to release the clutch.
  1. clutch slipping
    By pheno in forum 5 Series BMW
    Last Post: 05-06-2007, 09:28 AM
  2. Automatic slipping
    By Denasti in forum 5 Series BMW
    Last Post: 07-25-2006, 05:51 PM
  3. 1995 M3- Clutch Slipping? ADVICE NEEDED!
    By SF E36 in forum 3 Series BMW
    Last Post: 06-07-2006, 09:08 PM
  4. Replies: 3
    Last Post: 09-26-2005, 01:07 PM
  5. A slipping clutch, or??
    By DallasBill in forum 5 Series BMW
    Last Post: 07-10-2004, 11:15 AM
