Thread: Overheats when AC is on
    Ottawa, Ontario, Canada
    Default Overheats when AC is on
    1989 535i - >400,000km - have owned this car since Summer 2006
    First and foremost there is NO overheating problem with the AC off.
    - Aux. fan runs perfectly when the AC is on - aux. fan resistor replaced 1 yr ago
    - Main engine fan runs perfect when the AC is on
    - New Behr rad and BMW blue coolant - both done in 2006 <9,000km ago
    - Water pump and T-Stat - do not know the history of these two parts
    - Temperature gauge in sitting at 2 o'clock, not in the red zone though
    - City driving; backs off a wee bit on the highway
    So no problem with AC off, somewhat of a problem with AC on.
    Any suggestions - have I overlooked something? Something I need to live with?
    Blair...
    Jun 2006
    Bethesda, MD
    change the thermostat first, its cheap and very easy to replace (as long as you don't snap the bolts on the housing that is) and has a tendency to cause all sorts of weird cooling system problems. if the t-stat doesn't fix it verify that the fan clutch is good.
    Apr 2008
    Illinois
    Check the radiator vent hose & it's hole in the expansion tank -tiny hole- as it could be clogged with grime which causes overheating issues.
    Perhaps I'll replace the t-stat - the fan clutch isn't the culprit if the engine fan is running OK?
    The rad vent hose is the so called "pisser hose"? If so, I'll disconnect and check - the tiny hole in the expansion tank wasn't clogged.
    Apr 2008
    Illinois
    Quote Originally Posted by angusbn View Post
    yeah it is the "pisser hose"
  1. 2000 328CI Overheats in traffic, Fan not coming on?
    By CGrill in forum 3 Series BMW
    Last Post: 07-27-2006, 05:38 AM
  2. what should u do when ur car overheats?
    By pong in forum 5 Series BMW
    Last Post: 02-25-2005, 02:53 PM
