Results 1 to 8 of 8
Thread: will a 94 525i manual transmission work on a 92 525i auto to manual conversion?
    Jul 2005
    east bay area
    Default will a 94 525i manual transmission work on a 92 525i auto to manual conversion?
    please let me know
    thanx.
    Nov 2005
    M50 to M50... if you have Vanos (build date sept. 92 and forward), it's the exact same engine. Otherwise, they redid the cams only, not the whole engine, so it should fit just right. Check out Realoem.com with both build dates, I'm sure it will confirm it.
    Jun 2005
    Cleveland, OH
    Should Fit... check realoem to be sure...
    I miss my e34
    El Paso TX
    yes. just that you need to make sure you always order parts for a post 7/92 manual as it is the weaker getrag gearbox.
    you will need the matching shifter assembly, xmember, guibo and driveshaft...
    are you going to bastard shaft it and keep the auto diff, or getthe correct diff and use a full manual DS?
    m50s before 7/92 used a zf310, thus the difference in parts
    Jul 2005
    east bay area
    guys thanx for ur help but i decided to keep the 94 525i granite silber and part out the 92 auto alpine weiss..
    ok now i have a 9/93 production date e34 94 525im do i have the weaker getrag 5 speed? please let me know...
    El Paso TX
    ummm yes...
    9/93 is after 7/92
    Jul 2005
    east bay area
    so let me get this straight.
    from the above replys:
    any manual trans produced for an e34 after 7/92 is considered a superior transmission than pre 7/92?
    thanx.
    Quote Originally Posted by Young Pete View Post
    thanx.
    Uhm, from the above, it above appear otherwise. I can attest that the Zf.310 is pretty tight after almost 550k kms.
    Dave
  1. Replies: 1
    Last Post: 05-02-2008, 05:32 PM
  2. Replies: 2
    Last Post: 04-23-2007, 09:29 AM
  3. Replies: 3
    Last Post: 10-17-2006, 06:54 PM
  4. 525i auto to manual
    By v8anglia in forum 5 Series BMW
    Last Post: 05-11-2005, 02:12 PM
