Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Persistant "Brake Linings" warning
    Connecticut, USA
    Have been having this problem also for the last couple years, I always assumed it was the line grounding out somewhere.
    How do you test the sensor for continuity? Will a test light work fine? Also, are there any other spots common for fraying besides the front struts?
    1990 Islandgrun 535iM Sedan
    3k oil changes | Euro lights + trim | Eibach/Bilstein | EAT Chip
    Oldham, England
    Quote Originally Posted by ILoveMPower View Post
    Bulb and battery method is fine-all you are looking to confirm is that the circuit is complete. Just disconnect at the plug and put a probe on each of the terminals of the yellow lead. Bulb should light. If it doesnt, yellow wire or sensor are at fault. The thin yellow covered wires that go to the sensors could fail - mine did on one of the rears. Didnt look frayed but had broken inside somewhere. If it does light, you are looking for a break in the wiring going the other way. More likely at the front near the struts as the wiring moves with the angle of the wheels. HTH
    Just replace the sensor... it is that simple. You can test if that is problem by simply bypassing the sensor... stick a wire in both hole and tight... and if the warning sign go away, that is it.
    Factory skinny wire sensor break so easily.
    Jan 2007
    Dayton Ohio
    Brake sensor is a simple loop. Unplug sensor and check continuity across the two wires. If you have a light the sensor is good. No light sensor is bad.
    El Paso TX
    continuity requires a DMM
    Jan 2007
    Dayton Ohio
    Default light good... no light bad
    Sensor is really just a piece of wire. Continuity can be tested using a simple meter on ohms setting or with a couple pieces of wire, a bulb and a battery.
    I posted this about 10 times, trace the wire in the front where it goes through the fenderwell and up. There is a tendancy for it to rub through the insulation. If you doubt the sensors twist the wires together and then do your testing through the fenderwell.
  1. "PARKING BRAKE ON" warning?
    By nirvana19 in forum 5 Series BMW
    Last Post: 10-08-2007, 08:24 PM
  2. "Brake Linings" message bypass?
    Last Post: 02-18-2007, 06:46 PM
  3. OCB "Brake Linings" message
    By Jay 535i in forum 5 Series BMW
    Last Post: 12-28-2005, 10:12 AM
  4. Disabling "brake linings" message
    By Tcdoe in forum 5 Series BMW
    Last Post: 11-29-2005, 08:19 PM
  5. procedure to reset "brake linings" warning
    By micjordan in forum 5 Series BMW
    Last Post: 06-20-2004, 09:20 PM
