Results 1 to 10 of 17
Thread: Persistant "Brake Linings" warning
    Mar 2004
    NSW, Australia
    Default Persistant "Brake Linings" warning
    Boys and girls, Ive got new pads and sensors all round, still get the warning as soon as I turn the key! Inspected both sensors, all good, properly installed. What could it be? Search unsuccessful
    Feb 2007
    GreenHills East-Philippines
    same problem here
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    Feb 2007
    New Forest, ,UK,
    Did you remember the tiny metal spring clip that holds the sensor to the pad?? Also clean the connectors to the car carefully to get good contacts and don`t force them, they will align with a raised sector so look and be careful! I used to disconnect the battery briefly to reset but it was not needed, maybe it might be for you??
    Apr 2008
    Illinois
    "Brake Linings" always means the circuit of the pad sensor is shorted, so you have to check the metal clips, the sensor itself & the wire. sometimes old sensors would work fine.
    You have to double check the sensor... it could be bad or the wire too short that it pops off. I bought an aftermarket one and it was way too short. I also reused the old one that one day, the sign popped up... I then spliced the new sensor to the old wire so it is long enough and the sign went away.
    Sensor do go bad on BMW. Use mulimeter to confirm there is good continuity.
    Oldham, England
    If you get continuity through the sensors, disconnect them in turn and jumper the wiring back to find out which one ditches the message. If it stays on look for frayed wiring, especially round the front struts
    Mar 2004
    NSW, Australia
    Shall do
    Switch ignition on, do not start the car, leave ignition on for 60 seconds, maybe it is gone. Provided it is connected correctly. Once read that, not sure if it works though.
    Jan 2007
    Dayton Ohio
    When I had problems the sensors looked good but the front sensor had a broken wire. I unplugged the sensors one at a time and short circuited them. This removed the error. I then replaced the bad sensor with a new sensor. This is a simple closed circuit if there is a break you get an error code. Anyway that is my understanding
    El Paso TX
    Quote Originally Posted by bimmo_2007 View Post
    "Brake Linings" always means the circuit of the pad sensor is NOT shorted, so you have to check the metal clips, the sensor itself & the wire. sometimes old sensors would work fine.
    sensor is continuous if good, open if bad.
  1. "PARKING BRAKE ON" warning?
    By nirvana19 in forum 5 Series BMW
    Last Post: 10-08-2007, 08:24 PM
  2. "Brake Linings" message bypass?
    Last Post: 02-18-2007, 06:46 PM
  3. OCB "Brake Linings" message
    By Jay 535i in forum 5 Series BMW
    Last Post: 12-28-2005, 10:12 AM
  4. Disabling "brake linings" message
    By Tcdoe in forum 5 Series BMW
    Last Post: 11-29-2005, 08:19 PM
  5. procedure to reset "brake linings" warning
    By micjordan in forum 5 Series BMW
    Last Post: 06-20-2004, 09:20 PM
