Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Control Arms: Aluminum or Steel?
    Sep 2007
    Hamilton Ontario
    Quote Originally Posted by Blitzkrieg Bob
    My ///M5 and my Touring have the Aluminum arms and my 525 has steel.
    I can't tell any difference between the two on the ride of the car. But the shiny silver arms are nice to look at when you're under the car.
    Thats the other plus is no rust!!! However the nut will still likely rust
    Cleveland, Ohio USA
    My E34 is lowered with the Sachs kit, and I have steel arms w/ the upgraded bushings. It's very tight and corners well! It's too old to subject it to track conditions, so it only sees spirited driving on the back roads of Ohio. My /E39 touring has the factory sport suspension. I prefer the handling of the e34 on the backroads. The E39 is better suited for the long distance travels.
    i went with alum also. lower unspring weight
    Sep 2007
    Hamilton Ontario
    Hmm seems like I'll save some money and buy some steel control arms. Considering there is no real plus to Al
    Quote Originally Posted by EngPhys09
    The main plus is that they look nice every time you lie down on the road and look at the front of the car. Since I do this on a regular basis...
    Seriously, if you are the kind of person that cares what people think when you drive by (I don't get this concept personally,perhaps it is related to modern doof doof mentality?), perhaps you can gain value from the upgrade by the impression al LCAs leave on the pedestrians, every time you mow them down...
    That said I have them on my e34s. 2 reasons- one, I believe the non-lemforder alloy LCAs are almost as good as the Lemforder steel LCAs, and;
    I usually import my parts personally via airmail, so I see less difference due to the freight cost (lower weight) of the al LCAs.
    Anyone had a bad experince with the non-lem alloy LCAs?
    Mar 2007
    Liverpool UK
    I ordered Aluminium arms with m5 bushes and recieved them recently - I was amazed at the difference in wieght between the Alu and Steel! I don't know hoe much you'll 'notice' when driving but it all helps.
    And I agree, they do 'look' cool under the car too!
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Reading, UK
    If your roads are ****, like in the UK, if you've been driving your car for a loooong time and are used to its handling - you can notice a small difference. Over potholes and uneven surfaces the steel arms tend to plod around and skitter more - weird as the alu arms are lighter etc you'd expect them to jump more.
    I went alu->steel on my TDS tourer as it was the cheap option - but the car never quite felt the same on the front end again.
    Also I was told by a seasoned indy that you'll notice very little difference between the two, except on the track where the alu arms are more prone to flexing under load
    Apr 2008
    Illinois
    I asked some mechanic, he said Alum. gives more stability over bumps. & that's why they are more expensive.
  1. Used Aluminum Lwr Ctrl Arms - what to do?
    By RobPatt in forum 5 Series BMW
    Last Post: 07-09-2008, 04:25 PM
  2. Steel or Aluminum Strut Brace?
    By Jehu in forum 5 Series BMW
    Last Post: 12-01-2007, 08:20 PM
  3. steel vs. alum. control arms...............
    Last Post: 08-16-2005, 12:11 PM
  4. Steel/Aluminium lower control arms - Compatible?
    By UK E34 in forum 5 Series BMW
    Last Post: 07-21-2005, 05:40 PM
