Results 1 to 8 of 8
Thread: wiring question front lights
    Feb 2008
    Default wiring question front lights
    ewww this is the wiring connector to my front and fog lights... it's uglier in person...
    the questions are -if i cut the connectors will the wiring be colour-coded already for me? and is there anything running through this other than lights? (ie can i leave the battery connected?)
    Bay Area, CA
    The wires are color coded. It sounds like you are going to replace the connector but you can also try to clean it using electrical cleaner or some ethyl alcohol. Even brake cleaner will clean that stuff up. As long as the copper is shinny and clean, it should be OK.
    And that the connector securely locks is important too.
    Greg Mannino
    Feb 2008
    Quote Originally Posted by gmannino
    thanks - one of the pins broke off inside the female end
    i was going to replace the plug but i don't have a plug to do it with
    so.. what kind of voltage runs through wires like this? can i use a computer power supply plug? - i have some of those...
    That connector is junk. If by some miracle you manage to clean it up enough to restore function it will rot more in a New York minute.
    The wires are color coded, just splice them together and don't worry about a connector.
    Feb 2008
    aww ... i really should do it all at the same time but i don't have all the stuff... i'm going to have to take it off again twice more to do the fogs again and also the headlight washers... check out this 'fix' (it leaks) by a po! thanks for the tip ross but what do you say will any plug do temporarily?
    Feb 2008
    here's what i did... VERY fiddly - everything works ok.
    Quote Originally Posted by 525i winter driver
    Nice,
    I did something very similar with a fuel pump sending unit. Its a bit of a bugger getting them all connected, but it works!
    Dave
    Feb 2008
    Nice,
    Dave
    i have spent a lot of time staring at your fuel pump threads as i had some wiring problems there too, i have wiring problems everywhere! very fidgety all of it- nice job and thanks for the pics!
  1. Reverse Lights & Trunk Wiring Harness
    By ChefJRD in forum 5 Series BMW
    Last Post: 06-03-2007, 08:47 PM
  2. Question about rubber seal around parking lights - front
    Last Post: 01-08-2007, 01:42 AM
  3. HID wiring question
    By jarome in forum 5 Series BMW
    Last Post: 07-08-2005, 04:44 PM
  4. Stereo Wiring question
    By Incantation in forum 5 Series BMW
    Last Post: 06-26-2004, 02:57 AM
