Results 1 to 2 of 2
Thread: PCV Valve Replacement On V8's with M60 engine
    Default PCV Valve Replacement On V8's with M60 engine
    http://www.the7seriesregister.co.uk/...howtopic=10332
    This is from E32 730 and 740 V8, but same applies to 530 and 540 V8.
    Just in case you cannot open the link, you might first have to register at the U.K. board.
    It is under E32 Repairs/How to's
    May 2006
    NH
    Would it not be easier to just take the whole intake manifold off and remove the PCV Valve body then? That way you can put new throttle body and intake manifold gaskets too! BTW If I see some oiliy substance appearing to be coming from that Pipe end on the PCV is this normal or a sign of failure?
    1995 540i Manual build 1/95
  1. Idle valve replacement on M50 engines
    Last Post: 06-05-2007, 11:41 AM
  2. Valve cover gasket leaking after replacement
    By colo525i in forum 5 Series BMW
    Last Post: 02-19-2007, 05:17 AM
  3. Fumoto Engine Oil Drain Valve?
    By PhilipJCaputo in forum 5 Series BMW
    Last Post: 07-25-2006, 06:13 AM
  4. Heater Control Valve/s replacement
    By DCR in forum 5 Series BMW
    Last Post: 02-10-2006, 01:00 PM
  5. mid 90's v8's
    By wolfpack in forum 5 Series BMW
    Last Post: 02-06-2006, 09:44 PM
