Just to make sure that they really fit, make a test with original wheels and tires.Fitted e39 wheels with spigots
Hi all
I could do with some help in working out what’s wrong with my steering.
I am getting the shimming at 60mph but I can’t work out why
Things I have done
Replaced the thrust arms
Had the wheels balanced
Had the tracking done
Adjusted the steering box as after replacing the thrust arms it had some play in the steering
I can’t think what else it could be maybe the lower arms? I did get them at the same time I got the thrust arms but didn’t get round to fitting them, the car passed the mot without them I’m at a loss really as to what next
Thanks for any help or ideas
On a plus side after fittings a starting fix from ebay for the glow plugs my fuel pump now has power running to it and I was able to get the pump running but it will to be replaced as the fins are broken but now I have power running to it I don’t mind getting the pump![]()
1994 BMW E34 Touring Tds Auto (M51)
Nice car wish it was start uphill
i had a really bad shimmy so i replaced both arms on both sides, that sorted the problems even with E39 18 inch m5 wheels.
How did you adjust your steering?, i have a bit of slack now.
I don't have any other wheels to test with but i got some more spigots today and they seem to be a better fix hoping that might fix it. also i had steel wheel nuts so i put some alloy ones on fingers crossedOriginally Posted by shogun
Humm maybe if the new spigots dont fix the prob ill fix the other arms.Originally Posted by Antnicuk
Did your 18 inch wheels fit with out any mods i would like to get something bigger for mine.
For the steering i just adjusted the screw on the steering box worked well from what i can tell there is a "how to" on the site very easy and quick.
Originally Posted by calibra
Well tested the car with the new spigots and its worse than ever so I'm putting down to them not sure if the wheels or duff or maybe the spigots or on wrong i fitted them onto the wheel and then put the wheel on the car looks like I'm going to need new wheels Doh
i run the e39 M5 wheels and fitted them a couple of weeks ago, i am still waiting for my spiggots but it seems to run fine without them.
Spigots??
Do a search for "Hubcentric rings"
E30 318iS & BMW K1200LT
