Results 1 to 7 of 7
Thread: why can't I fit E39 alloys direct to my E34?
    Bristol, UK
    Default why can't I fit E39 alloys direct to my E34?
    I did this to my last E34 without any problems, but I recently read something
    about having to buy adapter rings or something.
    Why?! I don't really understand much about wheels, can someone please explain. What are the consequences of not buying these adapter rings?
    Matt
    malaysia
    Quote Originally Posted by mmaddock
    Matt
    The offset is different. Need some eccentric rings/hubs. Without it, you may experience some vibration.
    Rgds
    Bristol, UK
    I found the article I has previously read on bmwe34.net and it says that I just need hub centric rings due to E39 being 74mm hub and E34 72.5mm, which makes sense as I could get the E39 wheels to fit on my E34, but could not get the E34 wheels to fit on my E39 (don't ask!!!)
    Doesn't mention the offset. Is the offset a problem as well?
    Anyone got a definitive answer on this?
    Lincoln, NE
    Offset should not be a problem. The primary difference is the hub size, as noted.
    Mar 2004
    Pennsylvania
    Default I have M-Parallels from an 03 E39 540 sport....
    Matt
    and they work fine with the hubcentric ring.
    Ditto... but that is not a problem either... It can be corrected with a shim widely available.
    Bay Area, CA
    Quote Originally Posted by Mr Project
    yep. offsets are pretty much the same. it's just the hub bore size is different, and this may be corrected with hub centric rings.
  1. Direct Fit? 3.46 LSD on ebay
    By bimmerred535i in forum 5 Series BMW
    Last Post: 10-28-2009, 09:53 PM
  2. A little electrical help for V1 direct wiring
    By keystone in forum 5 Series BMW
    Last Post: 09-22-2006, 08:02 AM
  3. will alloys fit my e34
    By nelson22 in forum 5 Series BMW
    Last Post: 09-02-2006, 10:08 AM
  4. can someone please direct me to the best e46 site?
    Last Post: 10-09-2005, 02:07 AM
  5. Replies: 4
    Last Post: 08-04-2004, 09:03 AM
