Results 1 to 10 of 12
Thread: Engine mounts ay...
    Mar 2007
    Liverpool UK
    Default Engine mounts ay...
    I recently learnt that the engine mounts on the e34 are filled with some sort of liquid... Now that is interesting because for soooo long I've been wondering where I was leaking this from and I just couldn't find anything amiss! -
    Man do I feel foolish...
    I'm also wondering if this would contribute to my rough idle problem as everything else seems to be fine???
    Any hints/tips for changing these would be much appreciated. I've had a look around and it seems too simple to be true... Can I just take the nuts off, jack up under the engine and replace them? Do all the other parts attached to the engine have that much 'slack' - mainly worried about where the gearbox mates to the engine that kind of area. I'm hoping these aren't gonna be too expensive I've got new shocks/control arms/thrust arms on order!
    Many thanks in advance.
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Mar 2007
    Liverpool UK
    Quote Originally Posted by whiskychaser
    Not done it but dont see anything wrong with the plan. My only concern would be about sticking a jack under the sump and crushing it.
    Hey friend! I have similar concerns, hopefully a nice slab of wood will ease the pain... May even slap a small cushion under there if thats not OTT!
    Just to cheer you up for the weekend, you might want to look at the gearbox mounts too
    I was foxlike when I got a shop to do the clutch, I got them to put new gearbox mounts in and a new Guibo! I can't be bothered with that side of things with working on the floor. Get me some ramps and I'll happily explore!
    Mar 2007
    Liverpool UK
    Quote Originally Posted by gale
    Yep, liquid filled:
    Wo - that some freaky ****!
    A block of wood under the pan help, if not only giving a sense of security. If you bias the jack & raise only one side at a time, the other side you can put a bottle under the a/c compressor bracket.
    You must be thinking of a posh e34... I'm A/C~less!
    So you can just put the jack on one side of the sump and lift... Change the mount then move to the other side?
    Oldham, England
    Not done it but dont see anything wrong with the plan. My only concern would be about sticking a jack under the sump and crushing it. Just to cheer you up for the weekend, you might want to look at the gearbox mounts too
    Albuquerque, NM
    Yep, liquid filled:
    gale
    Jun 2006
    Bethesda, MD
    Quote Originally Posted by e34.535i.sport
    They made 535is without A/C? I know in most other countries the options vary dramatically but I always though that all of the top of the line 535s would have had that as standard.. were there 535s without power windows and the likes?
    Jan 2007
    San Jose, CA
    OMG, those things really have liquid in them? I thought someone was just making a joke because it's so impossible to keep from getting oil on the right-side mount when removing the oil filter. O_O
    Any chance of finding some simple, solid replacements?
    Quote Originally Posted by AngryPopTart
    Yes, you can just bolt the engine onto the frame with bolts without any cushion
    What a question.......
    They last for many years, but engine oil, Pentosin and other stuff dropping on them reduce their lifetime.
    Mar 2007
    Liverpool UK
    Quote Originally Posted by CaptainGoSlow
    Howdy,
    You should leave them until you get the kind of engine bucking we used to see from the old Fiesta engine when the mounts on that went... Although I suppose if you rev too hard with the extra power in this, it may just come right up and kiss you in the face.
    I'll be up for helping replace these along with the other stuff, have you found a good price on the mounts yet?
    LOL! It was indeed funny until the engine started bashing the bonnet up on acceleration... Those were the days.
    Going to ring my guy at CES now see what he can do mounts-wise... One thing after another doesn't even cut it anymore... Its one thing - with another!
    Peace out.
    Sep 2007
    Howdy,
  1. Replies: 3
    Last Post: 02-27-2009, 08:08 PM
  2. M60 engine mounts
    By artguy in forum 5 Series BMW
    Last Post: 02-25-2008, 10:55 AM
  3. M60 engine mounts
    By e34musician in forum 5 Series BMW
    Last Post: 09-06-2007, 07:31 PM
  4. M50 engine mounts
    Last Post: 09-04-2007, 08:15 AM
  5. M60 Engine Mounts
    By stargazer_61 in forum 5 Series BMW
    Last Post: 07-02-2006, 07:51 PM
