Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
Thread: on the hunt for noise from the rear....suspension?
  1. #21
    Dec 2007
    Northern(occupied) VA
    Quote Originally Posted by wiggy1406
    just Checked my dog bones....and the one where the noise is coming from is loose and bushes worn.....is it just a case of removeing the two bolts and replaceing bushes and bones ....bently manual doesn't go into detail....i.e is something going to ping off and collapse the rear suspension?
    Yea just make sure you have the suspension supported when you do this, Nothing will fall but it will be easier to put them back in.
    It is a simple task but a major pain in the ass imo.
    Conforti chip, K&N filter, Racing-dyn sways, EBC pad/rotor, SS brakelines, UUC DSSR, custom sound+alpine receiver, 17" PS2s, H&R/bilsports.
    "Speed is the product of doing everything right"
  2. #22
    Feb 2008
    London and Cambridge
    Quote Originally Posted by healtoeit
    As i have so far replace the radiator, head and gasket, distributor and rotor and timing belt and tensioner......i'm getting used to pain in the ass evolutions!!
    Mike
  3. #23
    Mar 2007
    Liverpool UK
    Quote Originally Posted by Tiger
    The sway bar links are more pain in the ass but with two floor jacks... it is quite easy to do.
    I changed mine fairly easily using one stand, just done one side at a time. The only difficult part is removing the bush-end of the old links. I used the old trusty hand saw.
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
  4. #24
    Don't even need to go that far. You spray some WD-40 or penetrating fluid and it will slip right off with prybar.
    Clean up the WD-40 before installing new links... and I used dishwashing liquid or Windex and soak the link and it slips right in... with some effort.
    WD40 and any oil will eat the rubber... so be careful!
  5. #25
    Mar 2007
    Liverpool UK
    I wish mine would have! I tried this for some time but didn't get anywhere... The ends of the bar had crusted up making them bigger than the hole in the links. Even after sanding it down I couldn't shift the little blighters with the trusty pry-pry!
    The washing up liquid was a must for me too when getting the new ones on... I wouldn't even attempt to do it without it! I used fairy... Softer on hands and bushes.
  6. #26
    Don't you have online auto supply to buy from in UK?
  7. #27
    Feb 2008
    Anyone know where in the UK i can get the dogbones and bushes??
    Mike
  8. #28
    NW UK
    just picked up a pair of both this afternoon from
    http://www.peter-michaels.com/
    £48 for both sets - pitman and sway
    probanaly not the cheapest? but had em in stock
    regards
    s
  9. #29
    Mar 2007
    Liverpool UK
    Quote Originally Posted by bigtallsam
    regards
    s
    Great stuff - let us know how you get on fitting and if it resolves your problem I hope it does because htose clunks are really annoying!
  10. #30
    NW UK
    job done!
    took a little longer than expected - took ages to get the sway/roll links off!
    any way she's back on the floor, just gonna have some tea then i'll take her out for a run
    p.s. gave the rear wings a push down and she does feel a lot stiffer already and i swear she's sitting a little taller at the rear!!??
    regards
    s
  1. Replies: 4
    Last Post: 11-24-2008, 09:21 AM
  2. Suspension noise
    By nixter in forum 5 Series BMW
    Last Post: 04-03-2007, 06:11 PM
  3. Suspension noise.
    By yy101 in forum 5 Series BMW
    Last Post: 12-01-2006, 05:48 AM
  4. Suspension noise...but from where?
    By liquidtiger720 in forum 5 Series BMW
    Last Post: 03-01-2005, 11:31 PM
  5. 535 Suspension Noise
    By hdaemon in forum 5 Series BMW
    Last Post: 06-10-2004, 03:12 PM
