Results 1 to 4 of 4
Thread: Torque Specs, Please?
    Default Torque Specs, Please?
    Drove up to my parents place to get a bunch of work done on my car ('90 535i), except I was an idiot and left my Bentley manual at home. Can anyone give me the torque specs for the following (And/or confirm the numbers I already have)?
    Brake Caliper to Mount:
    Thrust Arm @ Ball joint: 68 ft/lbs
    Thrust Arm @ Bushing: 90 ft/lbs
    Front Sway Bar End Links:
    Front Sway Bar Bushings (nuts on the retaining bracket):
    Damon H
    1990 535i 5spd 205,000mi
    More important than the actual torque # is when doing the bushings to have the suspension bearing the cars weight before they are tight so the bush isn't under stress at normal ride height.
    A good hearty grunt on the bushing, tight on the ball joint and good n snug on the links.
    Dec 2007
    Northern(occupied) VA
    Quote Originally Posted by hdaemon
    Don't need one, just make it tight enough so they do not rattle and you are set.
    Conforti chip, K&N filter, Racing-dyn sways, EBC pad/rotor, SS brakelines, UUC DSSR, custom sound+alpine receiver, 17" PS2s, H&R/bilsports.
    "Speed is the product of doing everything right"
    Your memory is good. You're right on.
  1. Anyone have the article with torque specs?
    Last Post: 09-06-2007, 07:44 AM
  2. M20 thermostat to head torque specs
    By drakede in forum 5 Series BMW
    Last Post: 01-04-2007, 08:05 PM
  3. torque specs for disc brakes
    By waltersa in forum 5 Series BMW
    Last Post: 08-06-2005, 08:37 PM
  4. Torque Specs
    By BCOOK2 in forum 3 Series BMW
    Last Post: 09-03-2004, 09:44 PM
  5. Torque specs?
    By Brians540ia in forum 5 Series BMW
    Last Post: 03-16-2004, 02:23 PM
