Hello John
My recommendation would be to go polybushes I fitted them to mine and they are holding up well with no diiscernable negatives that I can detect. Ferret is correct they don't need pressing in. Personally I would go German Swedish and French or EuroParts and buy arms without inner bushes and stick polybushes in em. They can be found on Fleabay for resonable price,that's where mine came from anyway.
I can totally see your point but at the end of the day I would only be able to afford the cheap arms here, like I have put in previously. Another option I would like to do but haven't really looked into is this... I could keep the lower arms as they are becasue they seem to be ok. Then I could remove the upper arms and get the powerflex bushings in there and see how it holds up once I get the new shocks in. The only problem I can foresee with this is removing the upper arm balljoints without damaging them (and the rubber boots), this could be tricky.
That is a useful piece of information! I have access to a press in work anyway but don't have any additional pieces which I assumed you would need to make the bushing sit perfectly in the middle.[/QUOTE]
