Originally Posted by
leicesterboy15
My main questions are how hard is it to replace the tank? Is it just a nuts and bolts job? How many connections are there to the tank (need to ensure I get them all)? Do I need to lower the exhaust? How do I de-pressurise the system?
My plan would be to build the new tank with new bits on the outside, remove the sender unit and pump from the old tank and put into new one. remove all connections to old tank, drop and remove it, replace tank with new straps / bolts and re-connect all connections.
Does that sound about right? Should I replace the expansion tank bits while i'm there? Is there anything else?
Are there any things to look out for (like filler neck etc). Also, are the plastic and metal fuel tanks interchangeable? They look slightly different on realOEM but it lists both for my car. Will I need all new bits (pump, sender etc) if I replace the metal one with a plastic one? is it worth it or best to stick to metal?
