The absolute values should be taken with a grain of salt. In other words, my compression tester will provide a different result than yours. What is most important, and tell-tale in this case, is the difference between cylinders.Originally Posted by rockitansky6831
Unless there is a problem with the way the test was conducted (elaborate for us if possible), we see a significant difference in cylinders 1 and 5. On that note, before I went any further interpreting results, I would conduct the test again in hope that something went awry.
Warm engine, throttle wide open etc. etc......... If you are at all in question of 'proper' compression test procedure, we have recently discussed the topic, just try a search.
Keep us informed,
Dave
