Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Car won't start: tried a jumper on the relay, next!?
    Montreal, Canada
    Default Car won't start: tried a jumper on the relay, next!?
    • First of all I changed the fuel pump, because I had a spare one from my old tank. Made no difference.
    • Second, I changed fuse 23, and still no go.
    • Now, I just put a jumper between 30 and 87 on the relay, and it made the pump work even without the key in the ignition, and there was a hissing noise coming from around the fuel rail... but the car will still crank without firing.
    any pointers would be greaaaatly appreciated! all of the above are stuff I learned about by searching the forums... but im out of resources now!
    Oldham, England
    Quote Originally Posted by Monastie
    Get a 12V bulb and connect to two pieces of wire. Put one end to ground and the other to 'slot' 30 or 87. If the bulb lights up, put it in the other slot and temporarily replace the relay with the wire in place. The bulb should light up when you crank. If not the relay isnt working. If thats OK, whip out a plug. If it looks wet with fuel you are not getting a spark. Check by connecting up the plug and holding the outer againt a good ground while you crank. You should get a healthy spark across the plug gap. Use rubber gloves or insulated pliars so you dont get a shock.
    Did you try starting it with the fuel pump relay jumper in place? If so, and it wouldn't start, then no need to try Whiskeys 12v bulb trick. Just pass go and collect $200. Or, just move on and check for spark.
    Dave
    Oldham, England
    Dave
    Dave is right. What I was trying to get you to do was prove that the relay and the circuit which energizes it were working so you wouldnt have to go back to it afterwards
    Any spark? If not, then crank position sensor.
    Montreal, Canada
    both pumps I have seem to be working.
    finally cheked for spark today, and there was none. pulled the first spark plug and pluged it back in the wire, made it touch the valve cover, and no spark at ignition.
    (btw, the bently dosent say you have to remove the airbox to reach the plugs.... but you kinda do! I had a hard time finding the plugs at first... ya im a noob)
    next? new plugs? then move to dme? or can I chek voltage from dme with a regular voltmeter (or is it too much voltage).
    Crank position sensor.
    Feb 2008
    how do your plugs look? spark plugs are likely not the problem if it suddenly stopped running, more likely distributor cap/rotor is fried in my limited experience, but it doesn't hurt to change the plugs at $25. the wear on them can be a good clue to your problem- check for deposits/corrosion.
    i found the distributor cap was awkward to remove on the m20 as it is jammed right up against the fan housing, but on most vehicles it's an easy check. check for cracks in the plastic cap and burns on the components.
    Feb 2008
    pics of an old fried distributor and rotor - hard to believe any electrons made it through all that crud, the car was running (well) still tho.
    tiger is probably spot on tho
    Just sand that oxidation down to brass metal and you can use it again... Old man's trick. However, if it is more than 5 years old.... change it out.
  1. How to make a oil and service reset jumper
    Last Post: 05-02-2010, 02:31 AM
  2. Fused Jumper Wire with On/Off switch...
    By artguy in forum 5 Series BMW
    Last Post: 01-17-2008, 10:07 AM
  3. Replies: 8
    Last Post: 07-02-2006, 07:58 PM
  4. M50 coils, main relay or fuel pump relay?
    Last Post: 05-31-2006, 07:48 PM
  5. Replies: 3
    Last Post: 07-08-2004, 09:49 PM
