Where did you get the sparks from? I got mine from the dealer and they reckoned they are pre-gapped... I checked them anyway but can't remember the exact value off hand.Originally Posted by vping
What is the recommended plug gap for a 1990 535I E34? Car is bone stock with no mods. I picked up a set of Bosch Platinum Plus 4034 plugs and want to install them tonight after work.
It's the least I can do for it after sitting for 5 years.
1952 MG TD
1963 MGB
1967 MGB GT Special
1974 MGB Roadster
1991 Ford Ranger
1997 BMW 528I
2000 Harley Davidson Softail
2004 Ford Expedition
They probably are pre-gapped. But I bet they arent the gap you needOriginally Posted by e34.535i.sport
I run NGK BKR6E in a stock engine and BKR7E in medium power turbo engines. In a stock engine they should be gappest about 0.032"
0.7 to .08 mm or .28 to .32 in.
Just did a tune up on a 535 with a set of NGK plugs that were pre gapped at .30 in.
I changed them but noticed that the ones I took out had some varnish on them on the face of the thread. The center looked good. The also smelled like un burned fuel. What would cause the smell? I tried to take the Dist Cap off but that looks like you need to take the fan off to get it out.
1952 MG TD
1963 MGB
1967 MGB GT Special
1974 MGB Roadster
1991 Ford Ranger
1997 BMW 528I
