Okay gents, finally got the other one in and have been out tanning the bastard all avo!
=======Embarrassing sidenote!=======
I finally figured out this morning why every E34 I've owned has had a tendancy to 'sink' in the ass - stupidity that's why.
You know that curved in section on the left in the boot? Perfect place for my 'small' toolkit to fit into, cool etc!
Except when I thought about it this morning, my small toolkit isnt small any more - it weighs nearly 30 kilos.
You see where this is going? Took the toolkit out and immediately my steering seemed a little more precisegot to where I was going and inspected the rear arches - suddenly the car's riding a good inch higher in the ass end!
I suspect it still needs new springs though - 30 kilos shouldnt cause it to deflect that much should it?
=======Sidenote over=======
Okay onto the good stuff - since I've driven her properly the last time I've fitted two new powerflex bushings and thrown some new dogbones at it.
Results?
Astonishing!
Pros:
- The rear end of the car feels firmly planted - no shake or shimmy like uber 'dont f**k with me, I'm not going anywhere' firmly planted.
- Due to the lack of flex in the subframe, the old butt dynometer has a sudden rejuvination and the car suddenly feels a lot more responsive - I know this is technically a lie but it's brightened up the driving experience somewhat.
- The rear grip has improved infinitely - standing on the loud pedal on a roundabout no longer causes the usual scrabbling noise accompanied with the "You're a tit" ASC light flashing like
- Rear steer *totally* eliminated
- Little noise/harshness brought into the cabin - for exceptions read below
- No excessive ass-bounce on the car going over uneven surfaces
Cons:
- Shows up how bad the front suspension is by comparison
- Rough surfaces make a lot more noise (though normal road surfaces have no difference)
- You feel small speedbumps a lot more, where the car used to sag and kind of smooth over them a little, it now transmits the full shock into the car if you drive over them at speed.
- An unexpected con, though when you think about it should really be expected: you cant get away with clunky shifts and you can hear your drivetrain taking up the slack every time you move off with a quiet clunk
Overall I'm extremely impressed, the back end of the car feels glued to the road, and there's no real compromises to be made! The rough terrain noises I've found actually make you feel more in touch with the road.
Irritatingly when it was up on the ramps today I discovered the cause of all the racket under load - the exhaust support mount is shattered right in the middle!
Just gotta buy meself a few new front end bits and then I can set to the bodywork, happy I've got the mechanicals sorted for now!
