Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Engine Super Hot after V belt renewal
    Mar 2007
    Liverpool UK
    Quote Originally Posted by Mordan
    it is night here. will do that tomorrow. I will let you know.
    if the impeller is destroyed, should I see debris when I drain the coolant? now that I think of it, just a minute before seeing the gauge red, I heard tap tap tap tap tap during 10 seconds at 60 miles per hour then it disappear. I thought this must be the 'tappets' which I heard where sometimes making a sound on the M40. then the sound disappeared and I thought "I'm lucky". then again I never heard this sound before and never heard what the 'tappets' sound like.
    anyways a minute after I saw the temp gauge lol. but i'm not sure when the gauge went up, because there is no bloody alarm. the light didn't even light up. does yours light up? *rant: there should be a sound alarm!!!
    I totally agree on the alarm... It should gong once the engine temp gets to 3/4 I think. It does gong once the coolant gets to a certain temp because mine did it, but by that time the engine is even hotter.
    Anyway it could have been the water pump, best way to check is to run the car and just watch the temp guage. If it goes past 12o'clock then just shut it off. Check the upper and other radiator hoses to check coolant is flowing.
    I'd probably change water pump/thermostat/coolant and maybe the fan clutch all in one go as its easy to do and not too expensive for peice of mind. You've got the link above on how to do it. The guy who wrote that sounds like a pro.
    Do a search for water pump - I've saw threads where the impeller's broken before so they will give you an indication of what you'll find when you ge the old one off.
    Good luck mate, hope you get it sorted.
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Apr 2008
    Belgium
    Default did another test
    Quote Originally Posted by e34.535i.sport
    here is the pulley of the water pump. everything looks fine. everyone who saw the belt says it is not straight. When removing the belt, I did move the fan a little on its axle. (i did not remove it)
    I did a refill of coolant, and after 2 mins driving, temp gauge is red again.
    the top hose was really hot but not immediately after i stopped the car, so I guess the thermostat is so so ok.
    one side note: I did put the heating max hot this time. but the heating did not work, air is cold even though I asked for hot air.
    i guess that's what I will have to do. new water pump and termo. and new radiator while I'm at it. damn.
    i'm pissed off I don't understand what went wrong. are you sure the new spark plugs change has nothing to do with increased engine power ?
    well I'm learning the hard way, like most of us.
    thx for your help
    Nov 2006
    Germany
    ...the top hose was really hot but not immediately after i stopped the car, so I guess the thermostat is so so ok.
    thx for your help
    So the belt looked funny after the change? Add in a hot upper hose (good thermostat) with the cold bottom hose and no heat inside= no pumpy the watery...
    Could this be a case of coincidental water pump self-failure during a belt change? The pulley (and belt) looking funny makes me wonder if the bearing went south without ruining the seal's integrity...
    Either way, you won't know for sure until you pull the water pump and see how it looks.
    I doubt putting more thermal load on the engine would work the pump any harder. I could see taking the thermostat out of its comfort zone (old t-stat) might hasten its demise but not the pump.
    Brian
    Mar 2007
    Liverpool UK
    If your getting cold air when asking for hot you may need to bleed the system for air... The procedure is on here in detail.
    I don't think the fan should move laterally - perhaps the water pump pulley has some play in the bearing putting it on an angle... If you change out all of those parts at least you will have peice of mind.
    I think i'm looking at a new radiator shortly too unfortunately, gonna set me back about £130 if i'm lucky.
    Apr 2008
    Belgium
    Default worse than the water pump
    Quote Originally Posted by bsell
    Brian
    took the car to a mechanic in my village. he put 2 liters of source water in the expansion tank. he played with the accelerator for awhile. expansion tank cap removed. no heating on the temp gauge. it stayed steady at 12 o'clock. the reason why still eludes me.
    he says:
    -belt not correctly aligned. water pump pulley too big and too far away from the engine. maybe water pump not the right one for the engine. (could that be possible???)
    -car without service book. he guesses the water pump failed and engine seriously overheated. cylinder head gasket certainly damaged. cylinder head might be damaged as well. water in expansion tank gets compression ripple back from the engine. reason why the enflated radiator is leaking near the top hose. can also be felt when running the engine with the oil cap removed. air pulsating out.
    -he adviced me buying a new motor if the cylinder head is damaged.
    what do you think? I certainly won't buy a new radiator until I fix the engine.
    Mar 2007
    Liverpool UK
    he says:
    Thats **** mate you have my sincere condolences, how long have you had the car?
    If the PO put the wrong pump on it then what a twat. It must be very similar if it fits though, maybe it just protrudes a tad too much outting the belt off alignment. This would put strain on the water pump bearing and would explain the failure I suppose.
    I'm not really in the know about the head damage so someone else may better advise but you should probably get a compression guage and test the compression on each cylinder. If it's just the gasket you could maybe do it yourself?
    If the head is goosed you could always buy one second hand... They are obtainable...
    http://cgi.ebay.co.uk/bmw-cylinder-h...QQcmdZViewItem
    Good luck, hope you get it sorted...
    Apr 2008
    Belgium
    thx for link. unbelievable. a head and its housing for 70 quids... I wonder if he can ship it to Belgium LOL. I don't think my grandma would be happy receiving THAT by mail
    got this car for one month. my cousin wants to learn and has a garage so we are planning to do an engine check and overhaul. If it is only the gasket, it should not be that difficult I reckon. I hope the head is fine. We will test the cylinder head in a special oven for cracks. only then I will buy a new pump, thermo and radiator. Yes the M40 is small guy, but still this little bastard deserves it.
    so now I wanna buy a new E34, while waiting for this one being repaired. I found this one. http://fr.autoscout.be/Details.aspx?id=132322815
    I like the picture of the engine. very few people show a pic of the engine here in Belgium.
    mate
  1. Registration/Plate Renewal: What do you pay?
    By artguy in forum 5 Series BMW
    Last Post: 02-04-2008, 06:14 PM
  2. Insurance renewal... good god!
    Last Post: 11-27-2007, 05:25 PM
  3. fan belt installation info - E32 M60 engine
    Last Post: 09-03-2006, 11:47 PM
  4. Belt Tensioning - E34 M60 engine
    By nhall22 in forum 5 Series BMW
    Last Post: 08-30-2005, 05:14 PM
  5. Replies: 7
    Last Post: 05-25-2004, 08:19 AM
