My ABS light comes on and stays on and my ABS kicks in very often when I'm braking...more often than not.
Its annoying more than anything and I'm concerned its a safety hazard. What could be wrong?
also RIP www.bmwe34.net :( :( :(
What happened to it?
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
do you run a staggered or non std tyre/wheel set up?
Possible your brake switch is bad...
In addition to cleaning the ABS sensors, you also might want to check the sensor leads - especially on the front wheels as they're subject to flexing when the car is steered and can develop internal breaks due to metal fatigue. Connect an ohmmeter to the pins in the connector and flex the lead up and down its length. If the ohmmeter spikes, you've found a fault. A pretty good Mercedes tech told me he ran into this problem fairly often in cars 10 years and older.
