Results 1 to 10 of 12
Thread: New engine, cranking, not getting oil pressure
    PA
    Default New engine, cranking, not getting oil pressure
    Hey all - I just put my engine together and its all good to go, I have a VAC upgraded oil pump. I have the spark plugs out and I crank for maybe 8 - 10 secs to get oil pressure and I am not getting oil pressure. If I hold the key to about 10 secs I get a bit of a squeak/rattle almost like a cam turning without oil or something - I don't like the sound.
    I filled the oil up and all, and I poured some down in the oil filter canister and watched it go down the center hole - i also filled the oil filter housing up some and depressed the spring loaded valve thing and watched some oil go down that.
    What do I do?
    If the pump wasn't primed with oil or Vaseline you will need to crank a long time befor any noticeable pressure builds. Don't know what the noise might be but if properly lubed during assembly there should be no worry. Maybe a cam chain tensioner?
    Sep 2005
    Dallas, TX
    I made this rig for the VG30DETT motor, and you could probably make something similar for the M50. Although I'm not sure how you'd make an attachment with the M50's oil filter assembly:
    http://www.twinturbo.net/nissan/300z...-oil-pump.html
    Nov 2004
    Gateshead,UK
    Hi Jon,
    It took a while to put the oil light out when I rebuilt my M20. In fact it was spinning on the starter for so long I was worried that the lube was going to dry out. One the engine fired up thelight went off.
    HTH,
    Shaun M
    PA
    Ugh guys I dunno I feel sick to my stomach thinking I have something more serious wrong
    Anyone know what each port does? #2 and #3 are spring loaded. Not sure what they do but I pushed the one down and pulled the other up to get oil everywhere in the canister. #4 accepts oil, as does #1. My oil level is high in the pan now, about 1/8" over the top line on the dipstick.
    Jan 2007
    San Jose, CA
    Can you take the valve cover off and lube what you can of the lobes? You seem very worried it's the cam.
    PA
    Quote Originally Posted by AngryPopTart
    Yeah I am 100% it was the top end/cams. The head was near dry. I pulled the VC added about 3/4 of a quart on the top end of the motor. Had my mother crank the car while watching the oil level inside the cannister with the lid off, and saw it rise! This got me pumped, so I dumped some more oil in the head, sealed up the lid, cranked, bam, pressure!
    Wellington,New Zealand
    god to hear that you are good to go Jon.A worrying interlude indeed!
    edit,this should actually be post #9
    PA
    Ross the feed is good on the turbo.
    Benneton (United Colors of)
    a good rule of thumb with oil pumps is to disconnect ignition and crank for 30 seconds beforehand.
  1. Low engine oil pressure 535i
    Last Post: 04-16-2008, 06:43 AM
  2. engine oil pressure
    By BigTed00 in forum 5 Series BMW
    Last Post: 03-17-2006, 12:43 PM
  3. engine oil pressure
    Last Post: 03-13-2006, 03:08 PM
  4. Engine not cranking!
    By hoodsstalker in forum 5 Series BMW
    Last Post: 01-18-2006, 09:23 PM
  5. Long cranking when engine is warm (M20)
    By Dan in NZ in forum 5 Series BMW
    Last Post: 06-05-2004, 09:15 AM
