It should drop that amount on its own. But if not a gentle lever will do it easilyOriginally Posted by Ferret
Gawd they took ages to get here....
After getting fed up of the car rear-steering I decided to have a go with some powerflex subframe bushings!
They're huge...
Todays big question is thus:
How easy is it to drop the subframe approx 1 inch to get the top half of this bushing over? They're press-fit together rubberised components, but you need to be able to get at the top and the bottom of the carrier to fit em!
Anyone have any suggestions... just jack it up, drop the subframe bolts on each side and pray?
Write-up will be coming when I figure this lot out!
S'cuse the expression, but I personally think that's cr*p.Originally Posted by BigKriss
I've been in two E34s now that have powerflex bushings in the subframe - and they've both been as quiet (or at least not noticably different) as the cars without. These arent solid blocks of plastic that just transmit every chassis resonation into the car - they're rubberised just enough to cut most of it out. They are however *hugely* noticable in the rear end stability - made a hell of a difference to how the cars drive.
Whiskychaser -mate, should make life easier! Where'd you position your jackstands while you were doing this job?
Erk! Which bit of the sil did you put the pressure on, the flat bodywork or the weld seam that sticks down? I Think it might be worth finding me some grooved bits of woodOriginally Posted by whiskychaser
They retail here for about $50AUD a side I think! (If my conversion factor is correct!)Originally Posted by BigKriss
http://www.powerflex.co.uk/products....3&catalog=0903
Will report back on ease of fitment etc next weekend, I've got the outlaws visiting this weekend so I cant get em fitted! *groan*
I put them under the sills with wood in between. I really didnt like doing it but the sills were absolutely fineOriginally Posted by Ferret
I put them under the welded seam. Think it was 2"x2" and about 6" long in the hope it would spread the load a bitOriginally Posted by Ferret
nice Im gonna be ordering some powerflex poly bushes sometime very soon
-Mike
