Results 1 to 7 of 7
Thread: Rattle
    Sep 2007
    Michigan
    Center bearing getting preloaded and unloading? Had an Audi once that did something similar until I changed the center bearing. Check the guibo also. Motor mounts in good shape?
    Seattle, Wa
    Quote Originally Posted by ahlem
    Don't believe the car has a "guibo". The fact that the noise is so intermittent has me baffled. I usually drive the car alone and the noise does not happen at idle speed but I have to start moving from a stop before I hear it. so it is kind of hard to check it on the fly.
    Thanks for the reply.
    Jim
    Oldham, England
    Exhaust touching something or a loose mounting?
    Seattle, Wa
    Quote Originally Posted by whiskychaser
    That sounds plausible, thanks.
    Seattle, Wa
    Default Bad Center Bearing, Tranny Mounts, and Drive Shaft
    To close out the thread...
    The noise come more often and louder. Don't know the order of failure but the forward joint of the drive shaft that attaches to tranny output was very stiff, the center bearing was totally shot as well as the tranny mounts.
    Replaced them all a few weeks ago.
    Car runs much smoother
    Jim
  1. Odd rattle
    By rickm in forum 5 Series BMW
    Last Post: 03-21-2007, 10:41 AM
  2. Rattle!!!
    By mamilapon in forum 5 Series BMW
    Last Post: 05-24-2006, 05:15 PM
  3. exhaust noise - rattle rattle
    By salansky in forum 5 Series BMW
    Last Post: 04-26-2005, 09:34 AM
  4. rattle under car
    By warmboy in forum 5 Series BMW
    Last Post: 07-17-2004, 01:34 PM
  5. Rattle Under Car
    Last Post: 06-10-2004, 08:42 AM
