Results 1 to 4 of 4
Thread: DIY leakdown test Questions
    Jul 2007
    Manassas VA
    Default DIY leakdown test Questions
    Im sure some of this should be obvious and i *think* I know...but ...
    For an m60 3.0l engine
    1. Where is a suitable place to hand crank each cylinder to TDC?
    The link http://www.geocities.com/dsmgrrrl/FAQs/leakdown.htm from Bruno's site says their was a slot in the drivers side wheel well. Is that true (or does this geocities site feature a random car?)
    2. Instead of an air compressor, could i run compressed nitrogen?
    I have no compressor, but i have abundant cheap access to nitrogen cylinders and can easily build a hose to go from a purging regulator to the quick connect of the leakdown tester.
    3. Can i just hit the ground running or do i need to 'unhook' stuff?
    I saw no mention of unplugging or disconnecting anything prior. No DME or Fuel pump relay disconnections (as a compression test calls for)?
    Thanks in advance,
    Terran
    "I have come here to chew bubblegum and kick a$$....and Im all outta bubblegum..." - Rowdy Roddy Piper
    Oldham, England
    Quote Originally Posted by BadAss95-530i
    Thanks in advance,
    Terran
    1. If you can crank your engine through a hole in the inner wing you have a problem. You should be looking for a big nut at the bottom of the block on the rad end. You will need to drop the sump guard to get at it properly
    2. Using nitrogen may move the goal posts. I'd stick to air
    3. For safety's sake I'd unplug the main and fuel pump relay (actually I wouldnt- I'd just get on with it but I think thats what you should do)
    Great Britain
    Whiskychaser has a point about nitrogen maybe moving the goalposts but if it were me then, being lazy, I'd also use nitrogen if convenient. Air is 79% or so nitrogen so I don't think it would be far off the readings you'd get using air. It might even be exactly the same as air?
    Jul 2007
    Manassas VA
    Quote Originally Posted by pingu
    Yeah thats what i was thinking. Using the regulator to step it down so that I would have only a 100psi consistantly in the cylinder seems to be the same as cranking a compressor up to 100psi in there...but maybe the compression rates of the two gases are diff which would throw off the flow % #s?
    The key is I went ahead and got some air anyways. turned out to be no big deal. The stealer wants $400 for the leakdown. Ive got an indy who may squeez me tomorrow for a compression test at $60 but it looks to be about 60 bones for tools/guages/adaptors for me to just attempt the much more telling leakdown test myself in combination with items i already have. Still in the planning stages though...
  1. leakdown test=solid, intake= solid?
    By BadAss95-530i in forum 5 Series BMW
    Last Post: 05-21-2008, 07:45 PM
  2. Stomp test result questions
    By Boone.Msi in forum 5 Series BMW
    Last Post: 05-07-2007, 09:37 PM
  3. Stomp test questions:
    By E34 530 in forum 5 Series BMW
    Last Post: 11-22-2006, 09:44 AM
  4. Replies: 3
    Last Post: 03-20-2005, 01:14 AM
  5. Leakdown results are in, and the winner is...
    By uberhahn in forum 5 Series BMW
    Last Post: 01-05-2005, 06:18 PM
