Results 1 to 10 of 10
Thread: Loose rear wheel... Can you tighen collar nut?
    Windy City
    Default Loose rear wheel... Can you tighen collar nut?
    I noticed my driver side rear wheel is loose. Likely bad wheel bearing or loose collar nut. Can you tighten the rear collar nut or do I need to replace rear wheel bearing? There isn’t any noise coming from the bearings.
    RICK
    BMW 1995 525i (Alpine White)
    baton rouge, loserana
    if the wheel is loose theres some kind of destruction going on, it's beyond a simple tightning
    Windy City
    Can you be more specific? Are you saying the wheel bearing is bad and needs to be replaced? I have tighten collar nut on other cars without changing wheel bearing and that seemed to fix the loose wheel issue. But I also heard that certain cars you can’t tighten collar nut.
    RICK
    the bearing is a sealed unit and requires special tools to replace, it runs a stub axle through the bearing but tightening it shouldn't have any effect on the bearing
    Mar 2007
    Liverpool UK
    I suppose tightening it up can't hurt if its just the nut come loose it'll be problem solved... If its still iffy you'll need to change the bearing more than likely.
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    you need to pull the axle to even see the nut for the stub shaft, it's on the inside
    Quote Originally Posted by e34.535i.sport
    Mar 2007
    Liverpool UK
    Now that I didn't know... If thats the case I'd be taking it to a shop!
    Does he not mean the big (36mm?) nut on the outside of the hub?
    Windy City
    For the rear, it's inside like Winfred described. You have to take the drive axle shaft off to get to it. That's not hard but changing rear bearing is. Need special tool to pull old bearing and push in new bearing. But if just collar nut tighening, I could do myself...
    RICK
    Mar 2007
    Liverpool UK
    Quote Originally Posted by Rick L
    Humble apologies - I thought we were thinking of the same thing! I hope you get it sorted without too much bother...
    Windy City
    I heard changing rear wheel bearing is a b*t*h so I'll take in. Thanks!
    RICK
  1. Trim, rear glass passenger side very loose.
    Last Post: 12-13-2006, 05:22 PM
  2. loose wheel
    By guinness in forum 5 Series BMW
    Last Post: 07-13-2006, 06:19 AM
  3. Loose Rear View Mirror
    By DonC in forum 5 Series BMW
    Last Post: 10-14-2005, 06:17 AM
  4. rear mtech spoiler loose, how to tighten?
    By mikemaster in forum 5 Series BMW
    Last Post: 09-14-2005, 05:57 AM
  5. Rear Windows Have Come Loose
    By John D in forum 5 Series BMW
    Last Post: 08-02-2004, 10:15 PM
