Results 1 to 5 of 5
Thread: My 525i seem to be losing a little coolant... advise?
    Mar 2008
    Bloemfontein, South Africa
    Default My 525i seem to be losing a little coolant... advise?
    Well, yesterday morning when I fired up the car, I got the COOLANT LOW message in the instrument cluster.
    Opened up the bonnet and coolant level was indeed low. Off to a service station and topped up coolant. Thing is, I cant seem to make out where the max mark on the bottle is.
    Anyhow, this morning before starting the coolant level was about 5mm lower than the level that I filled it to the day before.
    Checked it again now when I parked the car. Must be about 2cm lower than the level filled to on yesterday morning.
    I've looked around the engine bay and I can not see anywhere where the cooling system leaks coolant. Not a single drop on the floor after standing a while either.
    Opened oil filler cap and luckily no "mayonnaise" in there.
    Where could the coolant be going? Should I be concerned? I'll obviously be monitoring this closely.
    Oldham, England
    Quote Originally Posted by 525iZA
    The 'max' mark is about half way up the bottle. Its the one with the longer line but its a pain to see. Have a look at the chanel under the rad - a little weep might collect there. Feel round the back of the water pump pulley to see if the pump is weeping. Assume you checked hoses. You probably know these motors dont like to get hot. Do be aware that the low coolant warning wont come on with the engine running
    Mar 2008
    Quote Originally Posted by whiskychaser
    Thanks! I know these engines are a disaster waiting to happen when the cooling system isn't up to scratch.
    In that case, I think I overfilled and the excess might just have drained away. Phew!
    Will poke around a little more and see what I can find.
    Mar 2007
    Liverpool UK
    The radiator cap could be letting some out as vapour... I know some e34s had a recall and replacement on them due to a fault... Might be worth a phone call to BM if you cant find any trace?
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Roswell New Mexico
    i had a similar problem. turned out the raditor had small leaks in it, you could barly see it but the atifreeze gives it away
    anouther good place to look is the bottom of the coolant resivor. some times the large o ring will start to leak
  1. Losing Coolant Please Help!
    By farrk007 in forum 5 Series BMW
    Last Post: 01-07-2007, 05:15 AM
  2. Car overheated and losing coolant. Please help
    By kentish in forum 5 Series BMW
    Last Post: 07-19-2004, 01:07 AM
  3. M20 Headgasket, Losing Coolant...
    By ocampg in forum 5 Series BMW
    Last Post: 06-22-2004, 09:42 AM
  4. Losing Coolant
    Last Post: 03-22-2004, 05:46 PM
  5. Losing coolant...ideas?
    By TimGinCentralNJ in forum 5 Series BMW
    Last Post: 02-25-2004, 11:52 PM
