Results 1 to 9 of 9
Thread: thermostat test
    Mar 2008
    Default thermostat test
    hi, does anyone know how to test a thermostat while it is out the car or is there no such way?
    thanks
    Minnesota
    Default I usually take it to the kitchen and put it in a pan of
    Quote Originally Posted by dwaynos
    thanks
    boiling water with a thermometer. If it is still functioning properly you will see the spring contract as the temperature rises and then go back closed on the cool down.
    Good luck, it's easy.
    Jeff in MN
    87 535is 245k Recent top end re-work
    88 528e 290k
    90 535i 115k
    98 740i 115k New Magnaflow Cats, No More Codes
    Oldham, England
    Quote Originally Posted by Jeff in MN
    x1
    I would add that I have known them pass this test only to stick open a couple of weeks later. If in doubt I would put in a new one
    Windy City
    x3
    But also put in a thermometer and see if it opens right away at given temp of termostat.
    RICK
    BMW 1995 525i (Alpine White)
    Mar 2008
    do i put the whole thermostat in or just the bit which opens while i hold it
    Nov 2006
    Germany
    Don't be shy, throw the whole thing in the pot of water.
    Does anyone know the initial opening temp and the full open temp for these things? A spec for this must exist somewhere...
    I second the above recommendation to ditch a suspect thermostat as they don't cost all that much when compared to the time and trouble of swapping in a new one.
    Brian
    Oldham, England
    Quote Originally Posted by bsell
    Brian
    Yes chuck it in a pan but dont let it sit on the bottom-suspend it with a bit of string from a stick across the top of the pan. IIRC mine is 80 deg C. Once they hit temp they open fully. As for spec, I bet nobody guarantees they will even open within a degree or two
    Roswell New Mexico
    when mine when bad the car would start to run cold on the highway
    Yes you can test it. water and thermometer in a pan of water, etc., etc.
    Why bother with such an inexpensive part? If it is suspect or of unknown age just replace it.
    There are certain items that once removed aren't worth diagnosing.
  1. Thermostat Q
    Last Post: 07-13-2010, 07:50 AM
  2. Thermostat
    By bad2buck in forum 5 Series BMW
    Last Post: 04-19-2009, 03:31 PM
  3. How to Test+Change a Car Battery, test alternator
    Last Post: 02-07-2009, 09:18 PM
  4. 540 thermostat
    By yaofeng in forum 5 Series BMW
    Last Post: 04-28-2006, 08:59 PM
  5. Thermostat
    By spitfire in forum 5 Series BMW
    Last Post: 12-19-2004, 12:09 AM
