Results 1 to 10 of 18
Thread: '94 530im Fails Emissions Test
    Dallas, TX
    Default '94 530im Fails Emissions Test
    OK, the old 5er just failed the Texas State Emissions Test. Car has 140k mi. on it, and has been very carefully maintained according to prescribed schedules. No codes thrown in a while and the most recent one was for an O2 sensor, so I put in two new ones from BMA about a year ago.
    Here is the data from the test:
    HC (PPM) 228 max allowed 112 FAIL
    CO (%) 0.49 max allowed 0.62 PASS
    CO2 (%) 14.5
    O2 (%) 0.6
    Nox (ppm) 1156 max allowed 829 FAIL
    Dilution 14.99 need >6 PASS
    Question is, what to do next? Seems like I am way out of range on Hydrocarbons, so is trying another testing facility worth the $40 ? Is there any way to do some troubleshooting on my own ? Car doesn't have OBDII, so there were no other data available. Or, do I just need to go to the local indy and have them diagnose ?
    TIA
    Robert Callaway
    Dallas, TX
    '94 530im 143k mi
    '94 Land Cruiser FZJ-80 202k mi.
    "If I could have back all the time and money I ever spent on cars.......I'd spend it all on cars."
    East Brunswick, New Jersey
    Bad cats will cause the HC to be out of wack, sometimes NOx also. Are the cats original? If it turns to be the cats it could be expensive.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Dallas, TX
    Yes, I am afraid it could be the cats, and yes they are very expensive. Last time I priced them they were about $1200 ea, IIRC. That is the very, very last thing I would be willing to replace. All other rocks will turned over first.
    I just put some Redline Fuel System Cleaner in the car just now and will run it hard for a few days. It doesn't get a good workout in my normal commute to the office and back, so maybe there is some carbon build up going on. Also, if I understand the M60 motor, there is no EGR system, and the car relies on the cats to do a good bit of the work. I have a feeling the car sat too long before the test was performed and they were not really at proper temp. so getting them good and hot before the test could help a bit. I always run premium gas in it but we are in an area with up to 10% ethanol. Would that help or hurt?
    Ideas ?
    Thanks again.
    Robert Callaway
    Dallas, TX
    '94 530im 143k mi
    Jan 2007
    San Jose, CA
    Is that $1200 for factory replacements? On my 525i I just use an aftermarket replacement and it passed just fine, and it was alot cheaper than the factory replacement cat.
    Dallas, TX
    Yep, they were OE cats from BMA, but that was about four years ago when I priced them. Aftermarket cats for M60 cars were a bit dodgy back then and no one really recommended them.
    Robert Callaway
    Dallas, TX
    '94 530im 143k mi
    Jan 2008
    UK
    Quote Originally Posted by Super90
    I wouldnt bother going to the stupid expense of changing the cats when it is most likelly the lambda sensor which sits in the cats. Give that a go first it'll probably cost you less than £100 ($198)
    Dallas, TX
    Aren't lambda sensors the same as oxygen sensors (aka "O2 sensors") ?
    If so, that was done about 6k miles ago.
    Many thanks,
    R.
    Robert Callaway
    Dallas, TX
    '94 530im 143k mi
    Sep 2007
    Seattle, WA
    Many thanks,
    R.
    Yes, they're the same thing.
    Wellington,New Zealand
    and it will make some difference is oil is fresh,car(and cats) are hot....run some injector cleaner through too,just before you change the oil.
    Gone but not forgotten
    Dallas, TX
    We'll do. Thanks !
    Robert Callaway
    Dallas, TX
    '94 530im 143k mi
  1. Emissions test from hell . . .
    By gale in forum 5 Series BMW
    Last Post: 07-01-2008, 09:31 AM
  2. How to pass the emissions test
    By Snork in forum 5 Series BMW
    Last Post: 10-29-2007, 12:34 PM
  3. Intake Leak / Emissions Test?
    By Traian in forum 5 Series BMW
    Last Post: 10-28-2006, 12:00 AM
  4. Will an EAT cause me to fail an emissions test?
    By Jay 535i in forum 5 Series BMW
    Last Post: 09-08-2005, 08:42 AM
  5. Failed State Emissions Test
    By scott in forum 5 Series BMW
    Last Post: 06-24-2004, 03:49 PM
